[gdal-dev] ogr gml Box handling
Even Rouault
even.rouault at spatialys.com
Thu Dec 22 05:53:02 PST 2022
Andrew,
the GMLAS driver will fetch it as a string:
$ ogrinfo GMLAS:input.gml -oo remove_unused_layers=yes -al -q
Warning 1: Unhandled type: gMonthDay
Layer name: departedfeature
OGRFeature(departedfeature):1
ogr_pkid (String) = FDD58DEB0E04A917AB5BAEA4DFA65C70_DepartedFeature_1
fid (String) = osgb1000000849991256
osgb_boundedby_box_srsname (String) = osgb:BNG
osgb_boundedby_box_coordinates_decimal (String) = .
osgb_boundedby_box_coordinates_cs (String) = ,
osgb_boundedby_box_coordinates_ts (String) =
osgb_boundedby_box_coordinates (String) = 254337.630,617076.680
theme (StringList) = (1:Roads Tracks And Paths)
reasonfordeparture (String) = Deleted
deletiondate (Date) = 2022/09/26
Even
Le 22/12/2022 à 14:48, Andrew Terry a écrit :
> Hi Jukka,
> Thanks for responding and apologies for not including enough context.
> I’m converting GML into a SQL file form during testing using a command
> like:
> ogr2ogr --config GML_GFS_TEMPLATE test.gfs --config PG_USE_COPY YES
> -skipfailures -lco spatial_index=NONE -lco create_table=off -lco
> schema=test -lco create_schema=off -f PGDump output.sql input.gml
> An example GML with one feature would be:
> <?xml version='1.0' encoding='UTF-8' standalone='yes'?>
> <osgb:FeatureCollection
> xmlns:osgb='http://www.ordnancesurvey.co.uk/xml/namespaces/osgb'
> xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
> xmlns:xs='http://www.w3.org/2001/XMLSchema'
> xmlns:gml='http://www.opengis.net/gml'
> xmlns:xlink='http://www.w3.org/1999/xlink'
> xsi:schemaLocation='http://www.ordnancesurvey.co.uk/xml/namespaces/osgb
> http://www.ordnancesurvey.co.uk/xml/schema/v9/OSDNFFeatures.xsd'
> fid='LOCAL_ID_0'>
> <gml:description>Ordnance Survey, (c) Crown Copyright. All rights
> reserved, 2022-10-27</gml:description>
> <gml:boundedBy>
> <gml:null>unknown</gml:null>
> </gml:boundedBy>
> <osgb:queryTime>2022-10-27T00:10:00</osgb:queryTime>
> <osgb:queryChangeSinceDate>2022-09-15</osgb:queryChangeSinceDate>
> <osgb:departedMember>
> <osgb:DepartedFeature fid='osgb1000000849991256'>
> <osgb:boundedBy>
> <gml:Box srsName='osgb:BNG'>
> <gml:coordinates>254337.630,617076.680
> 254337.630,617076.680</gml:coordinates>
> </gml:Box>
> </osgb:boundedBy>
> <osgb:theme>Roads Tracks And Paths</osgb:theme>
> <osgb:reasonForDeparture>Deleted</osgb:reasonForDeparture>
> <osgb:deletionDate>2022-09-26</osgb:deletionDate>
> </osgb:DepartedFeature>
> </osgb:departedMember>
> </osgb:FeatureCollection>
> It defines an item’s unique fid and some basic attributes along with
> the “Box” as a bounding box / envelope indication of its location.
> Ultimately, the purpose is to form an indication of a feature to be
> deleted – in this case a point but not always.
> ogr2ogr will load the data but doesn’t understand the geometry type –
> and I note a bounding box doesn’t seem to be mentioned under types in
> the documentation
> A positive result would be any way to retain the content of
> gml:coordinates as a geometry or even as text which I could then
> handle within postgres as something I could turn into a geometry. My
> assumption has been that I would need to modify the gfs created by
> org2ogr to try and explicitly pull this element out
> Thanks
> Andy
> *From:*Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
> *Sent:* 22 December 2022 13:20
> *To:* Andrew Terry <andrew.terry at centremaps.co.uk>;
> gdal-dev at lists.osgeo.org
> *Subject:* Re: ogr gml Box handling
> Hi,
> Sorry but I do not understand at all what you want to do. Would you,
> if you read your question?
> Do you have some GML data that has a bounding box for each feature and
> you would like to convert the bbox into something? Would that be a
> second geometry for the attribute if the target format supports
> multiple geometries? Or an attribute that contains the bbox expressed
> as WKT of GeoJSON? Please give complete GML test data sample and an
> example about what would be the ideal result.
> In your example the bounding box seems to be a point so probably the
> data contains also just one point but probably you want to deal with
> more generic data.
> -Jukka Rahkonen-
> *Lähettäjä:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Andrew Terry
> *Lähetetty:* torstai 22. joulukuuta 2022 15.08
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] ogr gml Box handling
> Hi,
> Trying to pull in the bounding box / envelope “Box” when loading gml
> with ogr2ogr
> <osgb:boundedBy>
> <gml:coordinates>257023.700,620210.000
> 257023.700,620210.000</gml:coordinates>
> </gml:Box>
> </osgb:boundedBy>
> I’ve tried <GeometryElementPath>boundedBy</GeometryElementPath> in my
> gfs file.
> I’ve also tried seeing if I can pull through as a string using:
> <PropertyDefn>
> <Name>bbox</Name>
> <ElementPath>boundedBy|Box|coordinates</ElementPath>
> <Type>String</Type>
> </PropertyDefn>
> Any tips – if it’s even possible?
> Thanks
> Andy
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221222/06c32132/attachment.htm>
