[gdal-dev] netCDF with virtual file system (/vsicurl/) not working
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Feb 2 00:49:10 PST 2022
What is your GDAL version? Check with "gdalinfo --version"
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Stefan Blumentrath
Lähetetty: keskiviikko 2. helmikuuta 2022 10.36
Vastaanottaja: gdal-dev <gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] netCDF with virtual file system (/vsicurl/) not working
I have been using GDAL to access online data sources in netCDF successfully.
With Ubuntu 20.04, this unfortunately no longer works with the netCDF driver.
Here is a reproducible example:
gdalinfo -if netCDF /vsicurl/https://nbstds.met.no/thredds/fileServer/NBS/S2A/2021/02/28/S2A_MSIL1C_20210228T103021_N0202_R108_T35WPU_20210228T201033_DTERRENGDATA.nc
The original error message (before working around the HDF5 driver) has been that permissions for the userfaultfd system call were denied. But if I specify the netCDF driver, the format is not recognized. Downloading the dataset and opening It locally works.
I saw some possibly relevant changes:
https://github.com/OSGeo/gdal/pull/4508
https://github.com/OSGeo/gdal/issues/2412
Any hint on how to get that functionality back would be very much appreciated!
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220202/8baf1e29/attachment.html>
