[gdal-dev] GDAL, Proj and cacert
Howard Butler howard at hobu.co
Fri Feb 11 11:29:21 PST 2022
> On Feb 11, 2022, at 1:25 PM, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Thanks for this discussion Paul, I can also add into the chaos that Windows Server x64 has known issues with reading environment variables
What does this mean, specifically? Much of GDAL's behavior is controlled with environment variables.
Has Windows changed policies on how environment variables are expressed, consumed, and provided to processes? Is that simply just the case for running in an HTTP server like IIS?
Howard
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220211/f2b3e22a/attachment.html>
