[gdal-dev] Can't open postgrest service with ogr2ogr (via QGIS)
SIGéal sigeal at sigeal.com
Mon Feb 14 13:37:40 PST 2022
Thanks for your answer.
The url works fine in a browser.
Here is what "ogrinfo --debug on" returns :
> GDAL: Auto register C:\Program Files\QGIS
> 3.16.16\bin\gdalplugins\gdal_ECW_JP2ECW.dll using GDALRegister_ECW_JP2ECW.
> 3.16.16\bin\gdalplugins\gdal_GEOR.dll using GDALRegister_GEOR.
> 3.16.16\bin\gdalplugins\gdal_HDF5.dll using GDALRegister_HDF5.
> 3.16.16\bin\gdalplugins\gdal_MG4Lidar.dll using GDALRegister_MG4Lidar.
> 3.16.16\bin\gdalplugins\gdal_MrSID.dll using GDALRegister_MrSID.
> 3.16.16\bin\gdalplugins\ogr_OCI.dll using RegisterOGROCI.
> 3.16.16\bin\gdalplugins\ogr_SOSI.dll using RegisterOGRSOSI.
> HTTP: Fetch(http://mydomain:3000/rpc/wod_geojson.json)
> HTTP: libcurl/7.75.0 OpenSSL/1.1.1l zlib/1.2.11 WinIDN
> HTTP: These HTTP headers were set: Accept: text/plain, application/json
> ERROR 1: HTTP error code : 404
> FAILURE:
> Unable to open datasource
> `http://sigeal.net:3000/rpc/wod_geojson.json' with the following
> drivers...
Weird
Christophe Damour
Le 14/02/2022 à 20:26, Rahkonen Jukka (MML) a écrit :
> Hi,
> Does http://mydomain:3000/rpc/wod_geojson.json return data if you send
> it with browser?  Re-run the ogrinfo command with “--debug on” and see
> if you can capture the http requests that ogrinfo sends.
> -Jukka Rahkonen-
> *Lähettäjä:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *SIGéal
> *Lähetetty:* maanantai 14. helmikuuta 2022 20.54
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] Can't open postgrest service with ogr2ogr (via QGIS)
> Hi list,
> I have a PostgreSql stored procedure which returns a geojson feature
> collection created with json_build_object function. This web service
> opens fine in OpenLayers, however, when I try to open it in QGIS, with
> data source manager -> vector -> protocol -> geojson.
> A similar REST service served with pg_featureserv, works well...
>       Here are tests realised with curl and ogrinfo for failing
>       postgrest service and working pg_featureserv services :
>         PostGrest
>           curl answer :
> |StatusCode        : 200|
> |StatusDescription : OK|
> |Content           : {123, 34, 116, 121...}|
> |RawContent        : HTTP/1.1 200 OK|
> |                    Transfer-Encoding: chunked|
> |                    Content-Range: 0-0/*|
> |                    Vary: Accept-Encoding|
> |                    Content-Type: application/geo+json|
> |                    Date: Sun, 13 Feb 2022 07:35:55 GMT|
> |                    Server: postgrest/9.0.0|
> |                    {"type" : ...|
> |Headers           : {[Transfer-Encoding, chunked], [Content-Range,
> 0-0/*], [Vary, Accept-Encoding], [Content-Type, |
> |                    application/geo+json]...}|
> |RawContentLength  : 430979|
>           ogrinfo answer :
> |ERROR 1: HTTP error code : 404|
> |FAILURE:|
> |Unable to open datasource `http://mydomain:3000/rpc/wod_geojson.json'
> with the following drivers...|
>         pg_featureserv
>           curl answer :
> |StatusCode        : 200|
> |                    Date: Sun, 13 Feb 2022 07:33:51 GMT|
> |                    {"type":"FeatureCollection","features":[{"type":"Feature","geometry":{"type":"Po...|
> |Headers           : {[Transfer-Encoding, chunked], [Content-Type,
> application/geo+json], [Date, Sun, 13 Feb 2022 |
> |                    07:33:51 GMT]}|
> |RawContentLength  : 4474|
>           ogrinfo answer :
> |INFO: Open of
> `http://mydomain:9000/functions/webmapod_mdarret/items.json'|
> |      using driver `GeoJSON' successful.|
> |1: items (Point)|
> What could explain that 404 error for posgrest geojson web service ?
> Thanks for any hint,
> Christophe Damour
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220214/f03e444f/attachment-0001.html>
