[gdal-dev] Adding OSGEO4W and gisinternals docs in install doc?
Tamas Szekeres szekerest at gmail.com
Thu Feb 17 10:19:09 PST 2022
For gisinternals, the entire build including the dependencies is controlled
by a single Makefile
<https://github.com/gisinternals/buildsystem/blob/master/Makefile> which
controls the builds of the dependencies including how to obtain them from
the source repositories. The makefile also contains the necessary tweaks
that had to be applied in a dependency if that required for a successful
build.
Best regards,
Tamas
Even Rouault <even.rouault at spatialys.com> ezt írta (időpont: 2022. febr.
17., Cs, 17:29):
> Thomas,
> One criterion currently for inclusion is: "In this section we list a
> number of the binary distributions of GDAL all of which should have
> fully reproducible open source build recipes."
> I've not evaluated what the current situation of OSGeo4W or gisinternals
> is regarding this, especially regarding all direct and indirect
> dependencies of GDAL (or course, that must stop at the compiler level
> when using Visual Studio). I believe nowadays OSGeo4W must be closer to
> that aim of having fully reproducible builds, but I'm not sure to which
> extent. For gisinternals I'm not sure. It was my impression that the
> build recipees for the dependencies were not available, but maybe I'm
> wrong. I'll let the developers of those distributions comment further if
> they wish.
> Even
> Le 17/02/2022 à 17:17, Thomas Gratier a écrit :
> > Hi,
> > I regularly orient third parties to use GDAL utilities and for this
> > intent, point them to install section
> > https://gdal.org/download.html#binaries
> > For Windows, I did not see a user friendly section about how to
> > install it. I want to mention in the doc how to install with OSGEO4W
> > and https://www.gisinternals.com/index.html
> > Opinions? If ok, I will do a PR later on the github repo
> > Regards
> > Thomas Gratier
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220217/ad23c50b/attachment-0001.html>
