[gdal-dev] Use GitPod for GDAL?
Even Rouault even.rouault at spatialys.com
Fri Feb 18 14:38:23 PST 2022
Matt,
you need to install the "libproj-dev" package.
Looking at the CI build recipees is a source of good hints in general:
https://github.com/OSGeo/gdal/blob/6e6aff451dbcde450f051bff2f2e75ce6a4a3e6f/.github/workflows/cmake_builds.yml#L38
(this one has pretty much all the pre packaged dependencies. you don't
need all that)
Even
Le 18/02/2022 à 23:34, Matt Wilkie a écrit :
> This what I've come up with:
> https://gitpod.io
> Create new >> search for gdal >> select OSGeo/gdal
> On launch:
> -- Could NOT find PROJ (missing: PROJ_DIR)
> CMake Error at
> /home/linuxbrew/.linuxbrew/Cellar/cmake/3.22.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:230
> (message):
> Could NOT find PROJ (missing: PROJ_LIBRARY PROJ_INCLUDE_DIR) (Required is
> at least version "6.0")
> Call Stack (most recent call first):
> /home/linuxbrew/.linuxbrew/Cellar/cmake/3.22.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:594
> (_FPHSA_FAILURE_MESSAGE)
> cmake/modules/packages/FindPROJ.cmake:57
> (find_package_handle_standard_args)
> cmake/helpers/CheckDependentLibraries.cmake:303 (find_package)
> gdal.cmake:210 (include)
> CMakeLists.txt:206 (include)
> Attempted to remedy this with `sudo apt install proj-bin` but same
> error from `cmake .`
> The below adapted from
> https://github.com/maphew/gdal/blob/pr-5281-redux/CONTRIBUTING.md
> cd /workspace/gdal
> ./autogen.sh
> ./configure --with-python
> Fails with "configure: error: PROJ 6 symbols not found".
> tried `sudo apt install proj-bin` and repeated above, same error.
> Version of proj that's installed with this is 6.3.1.
> Try building Proj from source (takes awhile):
> cd /workspace
> wget https://download.osgeo.org/proj/proj-6.3.1.tar.gz
> <https://download.osgeo.org/proj/proj-6.3.1.tar.gz>
> tar zxf proj-*.gz
> cd proj-6.3.1
> ./configure
> make && sudo make install
> Now try again (takes much longer):
> cd /workspace/gdal
> ./autogen.sh
> make -j8
> sudo make install
> It works!
> . scripts/setdevenv.sh
> gdalinfo --version
> GDAL 3.5.0dev-39057d7396, released 2022/02/18
> uname -a
> inux osgeo-gdal-j6a7bhjf0c8 5.13.0-1013-gcp #16-Ubuntu SMP Tue Jan 18
> 14:31:35 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
> I'm still unable to successfully install a python wheel of gdal-utils,
> because pip is calling g++ which in turn is not finding libgdal, but
> it still feels like significant progress to get this far! :)
> -matt
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220218/d18ed119/attachment.html>
