[gdal-dev] Experiences with the WMS driver
Momtchil Momtchev
momtchil at momtchev.com
Mon Jan 3 07:08:24 PST 2022
gdalinfo does not contact the remote server at all, it extracts all
the information it displays from the URL.
Try replacing the hostname with something invalid, keeping all the
parameters and you will still get the same output.
On 01/01/2022 19:47, Joaquim Manuel Freire Luís wrote:
> But if I do
> gdalinfo
> "WMS:http://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=3170_21483_bg&CRS=CRS:84&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=FALSE"
> it seems to work but note the reported sizes and unreasonable resolution.
> Data axis to CRS axis mapping: 1,2
> Origin = (-180.000000000000000,90.000000000000000)
> Pixel Size = (0.000000335276127,-0.000000335276127)
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left (-180.0000000, 90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
> Lower Left (-180.0000000, -90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"S)
> Upper Right ( 180.0000000, 90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
> Lower Right ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"S)
> Center ( 0.0000000, 0.0000000) ( 0d 0' 0.01"E, 0d 0' 0.01"N)
> Band 1 Block=1024x1024 Type=Byte, ColorInterp=Red
> Overviews: 536870912x268435456, 268435456x134217728,
> 134217728x67108864, 67108864x33554432, 33554432x16777216,
> 16777216x8388608, 8388608x4194304, 4194304x2097152, 2097152x1048576,
> 1048576x524288, 524288x262144, 262144x131072, 131072x65536,
> 65536x32768, 32768x16384, 16384x8192, 8192x4096, 4096x2048, 2048x1024,
> 1024x512
Momtchil Momtchev <momtchil at momtchev.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220103/2ef75f2b/attachment.html>
