[gdal-dev] Bug in OGR library
Even Rouault even.rouault at spatialys.com
Mon Jan 10 02:42:29 PST 2022
Marta,
What is the bug exactly ?
"2 billion records" : by record, you mean cells, like a sheet with 2048
columns and 1048576 rows ? By quickly looking at the code I can't see an
obvious limitation, but that doesn't mean anything. Closer investigation
would be needed. Please file an issue at
https://github.com/OSGeo/gdal/issues/new with exact details how to
reproduce (number of rows/features, and columns/fields in particular).
But even if the writer side would work, the OGR reader side would
probably have issues as the whole spreadsheet will be loaded into RAM
and for 2 billion cells, I would expect at least 32 or more GB of RAM to
be needed. Perhaps spreadsheet software are able to cope with that in a
smarter way.
Even
Le 10/01/2022 à 11:27, Kopszak Marta - Partner Hurt a écrit :
> Dear Sirs,
> I ran into an error when exporting data through the OGR library to the
> .xlsx and .ods format. The bug occurs when there are more than 2
> billion records in the database. I know the problem was solved for
> other formats, e.g. csv. Will the problem be solved also for other
> formats (e.g. xlsx, .ods)? If this is not the correct e-mail, please
> forward this e-mail to the appropriate person.
> Kind regards,
> Marta Kopszak
> Logo Orange <https://www.orange.pl/>
> *Marta Kopszak*
> Współpracownik
> Rozwój Sieci Stacjonarnej, Wydział Rozwoju Planowania
> Orange Polska, gen. Romualda Traugutta 55, 50-416 Wrocław | RODO -
> informacja o danych <https://www.orange.pl/zobacz/rodo>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220110/2d5fdcf3/attachment.html>
