[gdal-dev] Discrepancy in proj values between ubuntu-small and ubuntu-full images
Rajsekar Manokaran rajsekar at gmail.com
Mon Jan 10 06:58:05 PST 2022
Hi Even,
Thanks for explaining the difference between the images.  You're absolutely
right:  I indeed assumed the two were using the same ellipsoids.  If I use
epsg:4269 (nad83 ell.) as the src, all the numbers are consistent.
Regards
Rajsekar
On Mon, Jan 10, 2022 at 8:05 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Rajsekar,
> One of the reason that the -full image is larger than the -small one is
> that the former includes > 500 MB of geodetic grids, whereas the later only
> includes very basic ones. (I've just amended
> https://github.com/OSGeo/gdal/blob/master/docker/README.md to make it
> clearer)
> As you do a WGS 84 to NAD83 transformation, the ubuntu-full image can use
> the HPGN grids, and in particular the Pennsylviana grid
> $ echo -77.75 40.16666666666666  | PROJ_DEBUG=2 bin/cs2cs
> '+init=epsg:4326' '+to' '+init=epsg:2271'
> [ ... snip ... ]
> Using coordinate operation axis order change (2D) + Inverse of NAD83 to
> WGS 84 (57) + SPCS83 Pennsylvania North zone (US Survey feet)
> pj_open_lib(us_noaa_pahpgn.tif): call
> fopen(/home/even/proj/PROJ-data/us_noaa/us_noaa_pahpgn.tif) - succeeded
> 1968499.39    -0.15 0.00
> Whereas the -small image has no such grid and will assume that NAD83 ==
> WGS84.
> In theory the result with the -full image should be more accurate, but it
> depends if somewhere in your workflow someone has not assumed that NAD83 ==
> WGS84 ...
> Anyway WGS 84 is literaly a moving and somewhat fuzzy target, so you
> shouldn't expect in general results to have an accuracy better than ~ 2m in
> any transformation involving it.
> Even
> Le 10/01/2022 à 15:21, Rajsekar Manokaran a écrit :
> Hi gdal devs and users,
> I came across a discrepancy in proj. values between ubuntu-small and
> ubuntu-full docker images even for the same gdal version tag.  I tried to
> convert a few coords from epsg:4326 to epsg:2271.  The coords are:
> Input:
> -77.75 40.16666666666666  # this is the center meridian, lat of 2271
> -75.18094433657971 40.25904959199275  # another sample point
> The outputs of all ubuntu-small-* images seem to be correct, but the
> ubuntu-full-* images have about 1 feet error (2271 uses US_SURVEY_FEET
> units).
> Here's how I run it:
> $ docker run --rm -i osgeo/gdal:"$tag" cs2cs '+init=epsg:4326' '+to'
> '+init=epsg:2271' < input
> where tag is the docker tag: "ubuntu-full-3.2.2", or "ubuntu-small-3.4.1",
> etc.
> Here are the outputs for the ubuntu-full images:
> output-ubuntu-full-3.2.2
> 2685535.97      44295.90 0.00
> output-ubuntu-full-3.3.3
> output-ubuntu-full-3.4.1
> Here are the outputs for the small images:
> output-ubuntu-small-3.2.2
> 1968500.00      -0.00 0.00
> 2685536.18      44296.27 0.00
> output-ubuntu-small-3.3.3
> output-ubuntu-small-3.4.1
> The first input is the center and so should translate to "(false east,
> false north)".  Going by that, the small versions seem to be more correct.
> Any idea why this difference in the values?
> Rajsekar
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220110/9acf9157/attachment.html>
