[gdal-dev] How to fix path for gdal .py scripts in Anaconda-Windows?
Even Rouault
even.rouault at spatialys.com
Wed Jan 12 11:09:06 PST 2022
I would have suggested to uninstall the offending proprietary software
:-), but perhaps checking that PYTHONPATH or PYTHONHOME are not defined
to an unexpected value will be sufficient
Le 12/01/2022 à 19:24, Rafael Lima a écrit :
> ## Expected behavior and actual behavior.
> I installed gdal on a Windows environment using anaconda and tried
> using one of the .py scripts (e.g., ogrmerge.py). I expected the
> script to make use of the gdal installed in such an environment, but
> it seems that the script finds another gdal installation (screenshot
> below), thus throwing an error. My question seems to be related to the
> one in
> https://stackoverflow.com/questions/69328298/cannot-run-a-py-which-requires-a-gdal-module-in-anaconda-prompt-nor-in-command,
> apparently unsolved. I was wondering what is the correct approach to
> make sure gdal scripts find the correct gdal?
> ## Steps to reproduce the problem.
> create a conda environment:
> conda create -n test1 gdal
> activate the environment
> conda activate test1
> call a gdal .py script
> ogrmerge.py
> In my case, that throws an error apparently because the script uses
> another gdal installation:
> ## Operating system
> Windows 10 Pro - 20H2 version
> ## GDAL version and provenance
> GDAL==3.0.2
> GDAL==3.4.0
> Thank you!
> Rafael
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220112/849e8c4f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220112/849e8c4f/attachment-0001.png>
