[gdal-dev] How to fix path for gdal .py scripts in Anaconda-Windows?
Idan Miara
idan at miara.com
Wed Jan 12 13:26:54 PST 2022
I had the same problem, here's my solution :
https://github.com/OSGeo/gdal/blob/master/swig/python/gdal-utils/osgeo_utils/auxiliary/batch_creator.py
Idan
On Wed, 12 Jan 2022, 23:22 Rafael Lima, <raplima at hotmail.com> wrote:
> I thought about uninstalling it to lol
> checking that PYTHONPATH or PYTHONHOME are not defined to an unexpected
> value will be sufficient
> It was something of the sorts. The paths were actually fine, but the
> "default windows app" is activated when calling a file with a .py
> extension. So calling ogrmerge.py on the terminal would activate the
> default app instead of the activated python =/
> Thanks!
> *De:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> em nome de Even Rouault
> <even.rouault at spatialys.com>
> *Enviado:* quarta-feira, 12 de janeiro de 2022 16:09
> *Para:* gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Assunto:* Re: [gdal-dev] How to fix path for gdal .py scripts in
> Anaconda-Windows?
> I would have suggested to uninstall the offending proprietary software
> :-), but perhaps checking that PYTHONPATH or PYTHONHOME are not defined to
> an unexpected value will be sufficient
> Le 12/01/2022 à 19:24, Rafael Lima a écrit :
> ## Expected behavior and actual behavior.
> I installed gdal on a Windows environment using anaconda and tried using
> one of the .py scripts (e.g., ogrmerge.py). I expected the script to make
> use of the gdal installed in such an environment, but it seems that the
> script finds another gdal installation (screenshot below), thus throwing an
> error. My question seems to be related to the one in
> https://stackoverflow.com/questions/69328298/cannot-run-a-py-which-requires-a-gdal-module-in-anaconda-prompt-nor-in-command,
> apparently unsolved. I was wondering what is the correct approach to make
> sure gdal scripts find the correct gdal?
> ## Steps to reproduce the problem.
> create a conda environment:
> conda create -n test1 gdal
> activate the environment
> conda activate test1
> call a gdal .py script
> ogrmerge.py
> In my case, that throws an error apparently because the script uses
> another gdal installation:
> ## Operating system
> Windows 10 Pro - 20H2 version
> ## GDAL version and provenance
> GDAL==3.0.2
> GDAL==3.4.0
> Thank you!
> Rafael
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220112/497083f0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220112/497083f0/attachment-0001.png>
