[gdal-dev] How to fix path for gdal .py scripts in Anaconda-Windows?
Matt.Wilkie at yukon.ca Matt.Wilkie at yukon.ca
Wed Jan 12 15:46:47 PST 2022
It was something of the sorts. The paths were actually fine, but the "default windows app" is activated when calling a file with a .py extension. So calling ogrmerge.py on the terminal would activate the default app instead of the activated python =/
If you want to manage from the command line what windows does with the .py extension see ASSOC and FTYPE commands
-          https://ss64.com/nt/assoc.html
-          https://ss64.com/nt/ftype.html
-          https://ss64.com/nt/fassoc.txt
-Matt
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220112/02df32a2/attachment.html>
