[gdal-dev] Faster alternative to GetFeatureCount?
Roman Breitfuss-Schiffer
roman.schiffer at gmail.com
Thu Jan 20 02:37:51 PST 2022
Hi Jon!
I don't know if there's an alternative to GetFeatureCount. At least I
couldn't find one in the API documentation. Maybe there's a workaround
I'm not aware of...
What you could do is wrap the call of GetFeatrueCount in a function
which is killed after some time (2 approaches are discussed here:
https://stackoverflow.com/questions/40915527/kill-function-after-a-given-amount-of-time).
With that approach the question remains of getting the value of
GetFeatureCount when the function gets killed. One could assume that
there are more features than 1 if the function takes too long. This
assumption might be a bit risky though...
Best regards
Roman
Am 20.01.2022 um 10:00 schrieb Jon Morris:
> I'm writing applications using the GDAL Python bindings and when I
> profile for performance, GetFeatureCount frequently comes out near the
> top. I'm often using it to check whether a spatial or attribute filter
> has returned any features and don't need the full count. When the
> layer contains millions of features, there would be a big performance
> improvement if we could exit the count early.
> Is there a better way of doing this? I've tried using GetNextFeature
> instead, but there must be quite a lot of overhead in that function as
> it is much slower. All I need to know is if the layer has has 0, 1 or
> >1 features, I don't need the actual count. Can anyone suggest the
> fastest way of doing this in Python? I'm using GDAL 3.3.1 at the
> moment but could upgrade if there is new functionality that would help.
> Thanks,
> Jon
> *Jon Morris*
> *Software Developer*
> e: *Jon.Morris at jbarisk.com* <mailto:Jon.Morris at jbarisk.com>
> t: *+44 (0)1756 799919* <tel:+44%20(0)1756%20799919>
> *www.jbarisk.com* <http://www.jbarisk.com/>
> Facebook <https://www.facebook.com/TheFloodPeople>
> LinkedIn <https://www.linkedin.com/company/jba-risk-management/>
> Twitter <https://twitter.com/JBARisk>
> YouTube <https://www.youtube.com/channel/UC0iatom2jYbW96voW0rlpCw>
> All JBA Risk Management's email messages contain confidential
> information and are intended only for the individual(s) named. If you
> are not the named addressee you should not disseminate, distribute or
> copy this e-mail.
> Please notify the sender immediately by email if you have received
> this email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number
> 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North
> Yorkshire, BD23 3FD, England.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/fb6d4364/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/fb6d4364/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/fb6d4364/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/fb6d4364/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/fb6d4364/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/fb6d4364/attachment-0009.png>
