[gdal-dev] Faster alternative to GetFeatureCount?
Ian Turton ijturton at gmail.com
Thu Jan 20 02:55:00 PST 2022
I'm not sure if it's a shortcut but couldn't you do a getFeatures loop with
a counter and break after 2 times round the loop, then your counter would
be 0,1 or 2 for your 3 cases.
Ian
On Thu, 20 Jan 2022 at 09:00, Jon Morris <Jon.Morris at jbarisk.com> wrote:
> I'm writing applications using the GDAL Python bindings and when I profile
> for performance, GetFeatureCount frequently comes out near the top. I'm
> often using it to check whether a spatial or attribute filter has returned
> any features and don't need the full count. When the layer contains
> millions of features, there would be a big performance improvement if we
> could exit the count early.
> Is there a better way of doing this? I've tried using GetNextFeature
> instead, but there must be quite a lot of overhead in that function as it
> is much slower. All I need to know is if the layer has has 0, 1 or >1
> features, I don't need the actual count. Can anyone suggest the fastest way
> of doing this in Python? I'm using GDAL 3.3.1 at the moment but could
> upgrade if there is new functionality that would help.
> Thanks,
> Jon
> *Jon Morris*
> *Software Developer*
> e: ​ *Jon.Morris at jbarisk.com* <Jon.Morris at jbarisk.com>
> t:  *+44 (0)1756 799919* <+44%20(0)1756%20799919>
> *www.jbarisk.com* <http://www.jbarisk.com/>
> [image: Facebook] <https://www.facebook.com/TheFloodPeople>
> [image: LinkedIn] <https://www.linkedin.com/company/jba-risk-management/>
> [image: Twitter] <https://twitter.com/JBARisk>
> [image: YouTube]
> <https://www.youtube.com/channel/UC0iatom2jYbW96voW0rlpCw>
> All JBA Risk Management's email messages contain confidential information
> and are intended only for the individual(s) named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> Please notify the sender immediately by email if you have received this
> email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number
> 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North
> Yorkshire, BD23 3FD, England.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Ian Turton
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/7179a156/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/7179a156/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/7179a156/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/7179a156/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/7179a156/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220120/7179a156/attachment-0009.png>
