[gdal-dev] GDAL/OGR 3.4.1 not reading S57 correctly
Momtchil Momtchev
momtchil at momtchev.com
Wed Jan 26 02:21:26 PST 2022
Can you post your C++ code? Generally, you have more chances of getting
an answer for this type of question on https://gis.stackexchange.com/
On 24/01/2022 06:36, dthorne at pivotmaritime.com wrote:
> Hi,
> So I am trying to get a test C++ project built to read S57 files using
> the gdal/ogr C++ library.
> I have previously used the C# library that is on there NuGet manager
> which states v2.4.4 and that seems to read the s57 without issues.
> Also tried python and that seems to read it with no issues.
> However, I am having a problem with the C++ test project. Having built
> the C++ library into the .lib and .dll files I have included them into
> a blank project and implemented the functions to read the s57 file,
> however it is only reporting 5 layers.
> These 5 layers are the same no matter the s57 file. And 4 out of those
> 5 layers are not actually layers.
> Using the autotest generated s57 file as a unit test to cross check,
> there is supposed to be 13 layers.
> Note: I had feedback from Even indicating the setup environment is
> probably wrong. And to set up the GDAL_DATA environment variable, so
> we've made an environment variable referencing the gdal/data folder
> and that hasn't fixed the problem, but I think it's on the right track
> as Even said they could reproduce the problem if not setup correctly.
> *Has anyone had success reading s57 files with a C++ 3.4.1. project
> that could possibly help get this going?*
> Link to reference Image: https://imgur.com/a/KwmqZSe
> Regards,
> Daniel
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Momtchil Momtchev<momtchil at momtchev.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220126/6b6a53c4/attachment-0001.html>
