[gdal-dev] cmake status update - 99% good news!
Even Rouault
even.rouault at spatialys.com
Wed Jan 26 10:49:55 PST 2022
did you update to master or did you try my pull request (not merged yet) ?
If only master, can you try to change the reference to "ws2_32.lib" to
"ws2_32" in cmake/modules/packages/FindHDF4.cmake as I suggested ?
Or perhaps change the if (WIN32) at line 91 to if (MSVC)
Le 26/01/2022 à 19:43, Joaquim Manuel Freire Luís a écrit :
> Don’t know which commit did it. Updated this afternoon and started to
> erroring right away with missing 'ws2_32.lib`
> *From:*Even Rouault <even.rouault at spatialys.com>
> *Sent:* Wednesday, January 26, 2022 6:36 PM
> *To:* Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] cmake status update - 99% good news!
> Le 26/01/2022 à 19:31, Joaquim Manuel Freire Luís a écrit :
> I do have HDF4 but before I was able to build till the end. I've
> here a gdal_w64.dll smiling to me. That's why I said it got worst.
> Sorry you lost me. Is https://github.com/OSGeo/gdal/pull/5179
> <https://github.com/OSGeo/gdal/pull/5179> helping or not ? If not
> helping, which commit in it is causing an issue ?
> Le 26/01/2022 à 17:26, Joaquim Manuel Freire Luís a écrit :
> > Joaquim,
> >> But I found two other new issues when adding more dependencies
> >> 1.
> C:\programs\compa_libs\gdal_GIT\frmts\mbtiles\mbtilesdataset.cpp(45):
> >> fatal error C1083: Cannot open include file: 'zlib.h': No such
> file
> >> or directory
> >> To work around this, I temporarily added zlib.h and zconf.h to
> >> frmts\mbtiles
> > Should be fixed by the first commit of
> > I'm afraid it got worst
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> C:/programs/compa_libs/gdal_GIT/build
> ninja: error: 'ws2_32.lib', needed by 'gdal_w64.dll', missing and
> no known rule to make it
> I'd say on the contrary that it helped the build to go further,
> didn't it ? My fixes are totally unrelated to a ws2_32.lib missing
> I see in configure.ac that we had the following logic
> dnl
> dnl Check if we need -lws2_32 (mingw)
> dnl
> echo "#include <winsock2.h>" > test_ws2_32.c echo "#include
> <ws2tcpip.h>" >> test_ws2_32.c echo "void foo() {}" >> test_ws2_32.c
> if test -z "`${CC} -c test_ws2_32.c 2>&1`" ; then
> LIBS="$LIBS -lws2_32"
> fi
> rm -f test_ws2_32*
> dnl
> dnl Check if we need -lpsapi (mingw)
> dnl
> echo "#include <windows.h>" > test_psapi.c echo "#include
> <psapi.h>" >> test_psapi.c echo "void foo() {}" >> test_psapi.c
> if test -z "`${CC} -c test_psapi.c 2>&1`" ; then
> LIBS="$LIBS -lpsapi"
> fi
> rm -f test_psapi*
> This hasn't been ported yet to cmake builds.
> I've ticketed that in https://github.com/OSGeo/gdal/issues/5180
> <https://github.com/OSGeo/gdal/issues/5180>.
> Hum, upon reflection, the error message would seem to indicate
> that we try to link to ws2_32.lib but it is not found in your
> environemnt
> Looking for ws2_32 in cmake build scripts, I see it is referenced in
> cmake/modules/packages/FindODBC.cmake: set(_odbc_required_libs_names
> odbccp32;ws2_32)
> cmake/modules/packages/FindHDF4.cmake: list(APPEND HDF4_LIBRARIES
> ws2_32.lib)
> Do you use any of ODBC or HDF4 in your build ? Could you try to
> disable them and see if it makes a difference ?
> Or maybe if you've HDF4, try to change the ws2_32.lib to ws2_32 in
> cmake/modules/packages/FindHDF4.cmake ?
> Even
> http://www.spatialys.com <http://www.spatialys.com>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220126/905f7e95/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220126/905f7e95/attachment-0001.png>
