[gdal-dev] cmake ignores EXPAT_INCLUDE_DIR & EXPAT_LIBRARY
Even Rouault
even.rouault at spatialys.com
Fri Jul 8 01:15:51 PDT 2022
> Such arguments are used by "Find-module Packages". However, the Modern
> CMake approach for is "Config-file Packages". For expat, GDAL prefers
> config (expat-config.cmake, expatConfig.cmake) providing targets named
> expat::expat or EXPAT::EXPAT.
> To use your own expat, make sure it has a config file which it is
> found via the search procedure, or use `EXPAT_ROOT`.
> You can read more in the CMake documentation for command
> `find_package`, in cmake-packages or in "Using Dependencies Guide".
The more simple hint here to use all custom packages you've installed in
$PREFIX would be to just specify -DCMAKE_PREFIX_PATH=$PREFIX
Even
http://www.spatialys.com
