[gdal-dev] ESRI FileGDB not available in Docker ubuntu-full after enabling WITH_FILEGDB
Even Rouault
even.rouault at spatialys.com
Thu Jul 14 02:00:31 PDT 2022
Travis,
Can you try the patch at https://github.com/OSGeo/gdal/pull/6079 ? (the
FileGDB part wasn't correctly ported when the Docker images have been
ported to CMake builds)
Even
Le 14/07/2022 à 02:20, Travis Featherston a écrit :
> I'm unable to see the ESRI FileGDB driver after enabling it in the
> Dockerfile
> Steps
> 1) git clone https://github.com/OSGeo/gdal.git
> 2) Edit docker/ubuntu-full/Dockerfile; set ARG WITH_FILEGDB=yes
> 3) ubuntu-full/build.sh --release --gdal v3.5.1 --proj master
> 4) docker run --rm osgeo/gdal:ubuntu-full-v3.5.1 ogr2ogr --formats
> |grep -i gdb
> Result
> It seems to build successfully without any warning/errors but only the
> Open driver is available.
> OpenFileGDB -vector- (rov): ESRI FileGDB
> Digging into the dockerfile and images ...
> osgeo/gdal:ubuntu-full-v3.5.1_builder
> /usr/local/FileGDB_API/lib/
> libFileGDBAPI.so libfgdbunixrtl.a libfgdbunixrtl.so
> /build_thirdparty/usr/lib/
> /usr/local/FileGDB_API/include/
> FileGDBAPI.h FileGDBCore.h Geodatabase.h
> GeodatabaseManagement.h Raster.h Row.h Table.h Util.h make.include
> /usr/include/
> /usr/lib
> /usr/include/
> <none of the header files are here, were they only needed during
> the gdal compile?>
> Is there a disconnect between these two lines in the docker file?
> Line #175 && cp /usr/local/FileGDB_API/include/* /usr/include \
> Line #319 COPY --from=builder /build/usr/include/ /usr/include/
> Any thoughts?
> My local env is wsl2 Ubuntu 22.04, with buildkit enabled
> Thanks,
> Travis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220714/ecf0d1c4/attachment.htm>
