[gdal-dev] GDAL internal error handling and implications for other language bindings
Even Rouault
even.rouault at spatialys.com
Sun Jul 17 11:41:43 PDT 2022
Sean,
that's a good and extensive analysis of error handling/reporting in GDAL.
> Consider OGRXLSDataSource::Open at
> https://github.com/OSGeo/gdal/blob/35c07b18316b4b6d238f6d60b82c31e25662ad27/ogr/ogrsf_frmts/xls/ogrxlsdatasource.cpp#L116-L118.
> The code resets the error context, pushes GDAL's silencing handler so
> that no other handlers (like GDAL's default which prints to stderr)
> receive error events, calls CPLRecode, and then executes more
> statements if CPLRecode set an error. This looks to me like GDAL's
> equivalent of what might be written in Python as
> |try: CPLRecode(...) except: CPLGenerateTemporaryFilename(...) ...|
|Yes, such error is fully handled internally by GDAL and hidden from the
user. Purely implementation detail|
> I see different behavior when rasterio calls GDALDatasetRasterIOEx to
> read data from a GeoTIFF. The silencing handler is not used, so error
> events are printed to stderr, but callers set new errors on top of the
> previous ones. A rasterio users sees the deeper causes of I/O failure
> in their logs, but can't react to them in their programs without extra
> work to parse errors out of log messages.
> Specifically, here's a snippet of errors printed to stderr that was
> provided by a rasterio user recently. These result from a call to
> GDALDatasetRasterIOEx.
> |ERROR 1: TIFFFillTile:No space for data buffer at scanline 4294967295
> ERROR 1: TIFFReadEncodedTile() failed. ERROR 1:
> /home/ubuntu/Documents/CDL_tiffs/2015_30m_cdls.tif, band 1: IReadBlock
> failed at X offset 189, Y offset 60: TIFFReadEncodedTile() failed. |
> "IReadBlock failed" is the last error set before GDALDatasetRasterIOEx
> returns and is the only one that rasterio can currently surface as a
> Python exception. It's specific about the block address at which a
> problem occurred, but vague about the nature of the root problem. Was
> it a codec error? Was it a memory allocation error? In this case it's
> a memory allocation error. The user found that they could retry data
> reads and get results the next time, presumably after their program's
> memory footprint shrinks sufficiently. What if we could surface enough
> error detail to a user that they could determine whether they could
> retry a read or not?
As mentioned in https://github.com/OSGeo/gdal/issues/6071, even for a
memory allocation error, it is not obvious to know if it is makes sense
to retry because some memory allocation errors are related to corrupted
data.
> I think this could make communication in the Rasterio issue tracker
> much more productive. More information about the causes of an error is
> right there in the traceback instead of being split between traceback
> and stderr (or other log stream). It could at least eliminate one
> round of asking for more error detail in a bug report. And there's the
> ability to catch an exception and go up the chain in code, potentially
> very powerful when you need it.
It looks to me that if GDAL's error handling could potentially be
enhanced with an error chaining concept. New API would have to be
devised (for error emitters and consumers), and relevant places modified
to use it. Would that be useful?
> I believe we've seen cases of GDAL functions that set errors while
> returning a success error code.
There are 2 sub cases:
a) the function emits a CPLError(CE_Failure, ...) , clears the error
state and returns something successful
b) the function emits a CPLError(CE_Failure, ...), doesn't clear the
error state and returns something successful
I'd say b) is probably mostly unwanted, and should be corrected to, at
the very least, clear the error state (*). But people could also say
that as soon as a CE_Failure is emitted and reaches the error handling
method (either the default one or a user-set), that it is it is not
caught by GDAL internals, the user could assume that the global function
would fail. Making such an assumption currently given the whole code
base would be overly cautious. Worth mentioning: the
CPLTurnFailureIntoWarning() function (introduced in
https://github.com/OSGeo/gdal/commit/f151e9f652b9d036cacdebf67ca88f59d5680cb3
and from what I can see , it is pretty much only used at the 2 initial
only places of gdal_misc.cpp of this commit), that as its name suggests
can cause any CE_Failure to be turned into a CE_Warning. It could be
handy to implement a "any CE_Failure that goes to the default or
user-set error handling method means that the function failed" policy,
but I'm not sure how we could implement this consistently in the code
base. That would require analyzing all potential code paths where this
could happen. Impractical (this also applies to the (*) at the beginning
of this paragraph)
(I guess we all agree that a successful function may emit one or several
CPLError(CE_Warning, ...) during its execution)
> It's possible that some functions return a failed error code while not
> setting any error.
Yes, sometimes error messages aren't really helpful when it is about
corrupted data. e.g if you parse WKB geometries there are tons of
potential error situations, and emitting a specific error for each one
would require a lot of coding effort, would bloat the code base & the
size of the GDAL binary.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220717/2a6e199b/attachment.htm>
