[gdal-dev] New behaviour of "PROMOTE_TO_MULTI" ?
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Mon Jul 25 01:53:47 PDT 2022
I have a MapInfo .tab file containing polygons, both simple and
multipolygons (and only polygons).
Using this command: (all ogr2ogr commands are one-liners, but examples
are split for lucidity)
ogr2ogr
--config PG_USE_COPY yes
-progress
-lco OVERWRITE=YES
-dim XY
-f "PostgreSQL" PG:"host=localhost port=5432 user=*** password=***
dbname=geodata"
FREDSKOV.TAB
will (correctly) create a table in Postgres of PostGIS type "Geometry"
If I change the command to:
ogr2ogr
-progress
-lco OVERWRITE=YES
-dim XY
* -nlt PROMOTE_TO_MULTI*
dbname=geodata"
FREDSKOV.TAB
I would expect the table to change the PostGIS type to "MultiPolygon".
However it still is registered as "Geometry".
Checking the table using SQL command:
SELECT ST_geometrytype(wkb_geometry), count(*) FROM mat.fredskov group by 1
affirms, that all geometries now is of type "ST_MultiPolygon".
AFAIK, this is a new behaviour. Or what ?
Postgres/Postgis version : 13.2, 3.1
OGR2OGR version: both 3.4 andf 3.6 dev.
Med venlig hilsen / Kind regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220725/ddca9b20/attachment.htm>
