[gdal-dev] gdal_translate differences between versions 3.4.3 and 3.5.1?
Matthew Savoie
matthew.savoie at colorado.edu
Wed Jul 27 08:03:47 PDT 2022
Hi Andrew,
> I have run this command with gdal 3.4.3 and gdal 3.5.1 and get different output files.
Can you compare the output of the two versions of gdalinfo ?
This should determine whether the difference is when reading or writing.
Good idea, I did that and there is no difference in the output of gdalinfo between 3.4.3 and 3.5.1 on the test.nc file.
Thanks,
Matt Savoie
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220727/359cf097/attachment.htm>
