[gdal-dev] Ogr2ogr taking too much time to process a MapInfo TAB file
Even Rouault
even.rouault at spatialys.com
Wed Jul 27 08:55:28 PDT 2022
Moises,
I've not reviewed in depth the MITAB driver, but reading from a .tab
file may require random access, and it is thus not surprising that
reading from a compressed file may exhibit poor performance. You might
try to set the VSI_CACHE config option / env variable to YES, but no
guarantee this will help for your use case.
Even
Le 27/07/2022 à 11:39, Moises Calzado via gdal-dev a écrit :
> Hi everyone!
> We're using ogr2ogr to convert MapInfo TAB files into CSV format using
> the following command:
> ogr2ogr -f CSV -skipfailures -makevalid /vsistdout/
> /vsizip/onLDU.zip -oo AUTODETECT_TYPE=YES -lco CREATE_CSVT=YES >
> test_2.csv
> The file weights ≈200 MB and the process is taking too much time to
> finish (almost 20 min), so we don't know if we're doing something
> wrong regarding the command that we launch.
> However, if we launch the same command against the .tab file instead
> of using the vsizip virtual file system, it takes less than 30 seconds
> to complete.
> Have you ever seen something like this? Do you know if it's expected
> that it takes too much time to process this kind of files, or we're
> doing something wrong?
> Thanks so much for your help in advance,
> Regards!
> *Moises Calzado*
> Support Engineer
> (US) +1 917 463 3232 | (ES) +34 911 165 823 | mcalzado at carto.com
> <https://spatial-data-science-conference.com/2022/newyork/>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220727/db57ae98/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220727/db57ae98/attachment-0001.png>
