[gdal-dev] New behaviour of "PROMOTE_TO_MULTI" ?
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Sun Jul 31 01:00:11 PDT 2022
Thanks to Hugues and Richard for responding to my questions.
However, I'm using the ogr2ogr inside a DOS .cmd file like this:
for /R D:\tmp %%f in (*.tab) do ogr2ogr --config PG_USE_COPY yes
-progress -lco OVERWRITE=YES -lco SCHEMA=mat -dim XY -a_srs EPSG:25832
-f "PostgreSQL" PG:"host=localhost port=5432 user=*** password=***
dbname=geodata" "%%f"
I.e. iterating through a directory plus sub-directories and converting
every found tab file into a table into schema "mat" using ogr2ogr
The tab files contains either points, linestrings or polygons. Polygons
and linestrings can be a mix of simple and multi-objects. Each tab-file
contains only one main type.
So I can't use "-nlt multipolygons". And the point of this project was
to get rid of a fairly complex postgres based function that checks an
uploaded table and change its geometry type using "alter table ... using
st_multi(geom)" type of commands.
That was why I tried to use "-nlt promote_to_multi". According to this
mail:
https://lists.osgeo.org/pipermail/gdal-dev/2012-September/034128.html
Even Rouault describes the exact behaviour I'm looking for: Simple
linestrings / polygons will be changed to multi types and points will be
left alone. And the geometry type will be set to a "multi*" as needed.
What actually happens is that linestrings, polygons /and/ points all are
changed to multi type, but the geometry type remains "Geometry".
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 25-07-2022 kl. 15:52 skrev Hugues François:
> Hi,
> I guess you should either
> => drop the created table prior to launch the ogr2ogr command with the
> -nlt PROMOTE_TO_MULTI switch
> => or maually alter the existing table: ALTER TABLE schema.table ALTER
> COLUMN geom TYPE geometry(MultiPolygon, SRID) using ST_MULTI(geom)
> HTH,
> Hug
> *De: *"Richard Greenwood" <richard.greenwood at gmail.com>
> *À: *"Bo Victor Thomsen" <bo.victor.thomsen at gmail.com>
> *Cc: *"gdal dev" <gdal-dev at lists.osgeo.org>
> *Envoyé: *Lundi 25 Juillet 2022 15:32:35
> *Objet: *Re: [gdal-dev] New behaviour of "PROMOTE_TO_MULTI" ?
> Have you tried -nlt MultiPolygon?
> On Mon, Jul 25, 2022 at 2:54 AM Bo Victor Thomsen
> <bo.victor.thomsen at gmail.com> wrote:
> I have a MapInfo .tab file containing polygons, both simple and
> multipolygons (and only polygons).
> Using this command: (all ogr2ogr commands are one-liners, but
> examples are split for lucidity)
> ogr2ogr
> -progress
> -lco OVERWRITE=YES
> -dim XY
> password=*** dbname=geodata"
> FREDSKOV.TAB
> will (correctly) create a table in Postgres of PostGIS type
> "Geometry"
> If I change the command to:
> ogr2ogr
> -progress
> -lco OVERWRITE=YES
> -dim XY
> * -nlt PROMOTE_TO_MULTI*
> FREDSKOV.TAB
> I would expect the table to change the PostGIS type to
> "MultiPolygon". However it still is registered as "Geometry".
> Checking the table using SQL command:
> SELECT ST_geometrytype(wkb_geometry), count(*) FROM mat.fredskov
> group by 1
> affirms, that all geometries now is of type "ST_MultiPolygon".
> AFAIK, this is a new behaviour. Or what ?
> Postgres/Postgis version : 13.2, 3.1
> OGR2OGR version: both 3.4 andf 3.6 dev.
> Bo Victor Thomsen
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Richard W. Greenwood
> www.greenwoodmap.com <http://www.greenwoodmap.com>
> [Fichier texte:ATT00001]
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220731/7c14cb8f/attachment.htm>
