[gdal-dev] building python bindings after cmake compilation
Greg Troxel
gdt at lexort.com
Thu Jun 2 16:03:50 PDT 2022
Saulteau Don <sault.don at gmail.com> writes:
> I have gdal 3.5.0 built using the new cmake system.
> /chroot/src/build <- cmake build directory
> /chroot/src/gdal <- src directory
> /chroot/src/gdal/swig/python
> My cmake is ran from the /chroot directory:
>> cmake -B build -S gdal \
>> -DCMAKE_BUILD_TYPE='None' \
>> -DCMAKE_INSTALL_PREFIX='/usr' \
>> -DBUILD_PYTHON_BINDINGS='OFF' \
>> -Wno-dev
>> cmake --build build
> Then to make the python bindings via swig:
>> cd gdal/swig/python
>> python setup.py build
> When the `python setup.py build` is running it can't find gdal-config with
> the following errors:
This may not be how you want to do this, but if you install the lib and
then build python as a separate step, it will probably go better. I
am unclear on how this is supposed to work; pkgsrc builds non-python
libs and then python as separate packages.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220602/4efaf76a/attachment.sig>
