[gdal-dev] Why can't find_package(GDAL CONFIG) find GDAL_LIBRARIES?
Even Rouault even.rouault at spatialys.com
Tue Jun 7 00:28:42 PDT 2022
Tom,
GDAL_LIBRARIES and GDAL_INCLUDE_DIRS are indeed not defined. You have to
use the "GDAL::GDAL" target in a
target_link_libraries() statement which propagates both include and
linking requirements and tends to be the modern CMake practice, although
admitedly not very clearly documented in target_link_libraries()
official documentation. I found
https://schneide.blog/2016/04/08/modern-cmake-with-target_link_libraries/
which deal with that.
So a typical minimum CMakeLists.txt of a project using GDAL is (this is
actually
https://github.com/OSGeo/gdal/blob/master/autotest/postinstall/test_c/CMakeLists.txt
used in GDAL continuous integration to test usage of GDAL from a
third-party library/application)
cmake_minimum_required(VERSION 3.0)
project(test_c C CXX) # CXX for properly linking GDAL
find_package(GDAL CONFIG REQUIRED)
add_executable(test_c test_c.c)
target_link_libraries(test_c PRIVATE GDAL::GDAL)
I've created https://github.com/OSGeo/gdal/issues/5875 to track we need
documenting that.
Note: If you really wanted to get the equivalent of GDAL_INCLUDE_DIRS
and GDAL_LIBRARIES, you could use the following expressions:
$<TARGET_PROPERTY:GDAL::GDAL,INTERFACE_INCLUDE_DIRECTORIES>
$<TARGET_PROPERTY:GDAL::GDAL,INTERFACE_LINK_LIBRARIES>
Even
Le 07/06/2022 à 02:02, Tom O'Reilly a écrit :
> I've just built and installed GDAL 3.5.0 on ubuntu 20.04, with cmake
> 3.5.0 and make. It appears that 'make install' installs needed cmake
> config files for GDAL:
>     -- Installing:
>     /usr/local/lib/x86_64-linux-gnu/cmake/gdal/GDALConfigVersion.cmake
>     -- Installing:
>     /usr/local/lib/x86_64-linux-gnu/cmake/gdal/GDALConfig.cmake
> I'm building my own project that uses GDAL. The CMakelists.txt invokes
> find_package() and prints out resulting variables:
>     if (GDAL_FOUND)
>       message("GDAL Found!")
>       message("GDAL_INCLUDE_DIRS: ${GDAL_INCLUDE_DIRS}")
>       message("GDAL_LIBRARIES: ${GDAL_LIBRARIES}")
>       message("GDAL_VERSION: ${GDAL_VERSION}")
>     else()
>       message("GDAL not found")
>     endif()
> Running cmake indicates that GDAL_FOUND is true, GDAL_VERSION is set
> to the expected value(3.5.0), but GDAL_LIBRARIES and GDAL_INCLUDE_DIRS
> are empty:
>     GDAL Found!
>     GDAL_INCLUDE_DIRS:
>     GDAL_LIBRARIES:
>     GDAL_LIBRARY:
>     GDAL_VERSION: 3.5.0
> Why are GDAL_LIBRARIES and GDAL_INCLUDE_DIR empty?
> Thanks
> Tom
> Thomas C. O'Reilly
> Monterey Bay Aquarium Research Institute
> 7700 Sandholdt Road
> Moss Landing, California 95039-9644
> 831-775-1766 (voice)
> 831-775-1620 (FAX)
> oreilly at mbari.org (email)
> http://www.mbari.org (World-wide Web)
> "The machine does not isolate us from the great mysteries
>  of nature, but plunges us more deeply into them."
>    - ANTOINE DE SAINT-EXUPERY
>      "Wind, Sand, and Stars" (1939)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220607/72dfa38a/attachment-0001.htm>
