[gdal-dev] Why can't find_package(GDAL CONFIG) find GDAL_LIBRARIES?
Tom O'Reilly
oreilly at mbari.org
Tue Jun 7 09:52:04 PDT 2022
Thanks for this information Even - very useful and interesting.
I'm still a cmake newbie, and one cmake aspect that drives me nuts is its "inconsistency" when it comes to finding packages ("Should I call find_package(X) with MODULE or CONFIG?", "Is it X_INCLUDE_DIRS or X_INCLUDES?"). So my CMakeLists.txt tend to get complex pretty quickly.
The method you describe looks elegant and straightforward, and it works for GDAL. In general for package 'X', is the following *guaranteed* to produce a usable target of form "X::X" or exit if package X is not found?
# Find package X
find_package(X CONFIG REQUIRED)
add_executable(test_c test_c.c)
target_link_libraries(test_c PRIVATE X::X)
If I could rely on that form, my CMakeLists.txt files would be much simpler!
Thanks
Tom
Thomas C. O'Reilly
Monterey Bay Aquarium Research Institute
7700 Sandholdt Road
Moss Landing, California 95039-9644
831-775-1766 (voice)
831-775-1620 (FAX)
oreilly at mbari.org (email)
http://www.mbari.org (World-wide Web)
"The machine does not isolate us from the great mysteries
of nature, but plunges us more deeply into them."
- ANTOINE DE SAINT-EXUPERY
"Wind, Sand, and Stars" (1939)
From: "Even Rouault" <even.rouault at spatialys.com>
To: "Tom O'Reilly" <oreilly at mbari.org>, "gdal-dev" <gdal-dev at lists.osgeo.org>
Sent: Tuesday, June 7, 2022 12:28:42 AM
Subject: Re: [gdal-dev] Why can't find_package(GDAL CONFIG) find GDAL_LIBRARIES?
Tom,
GDAL_LIBRARIES and GDAL_INCLUDE_DIRS are indeed not defined. You have to use the "GDAL::GDAL" target in a
target_link_libraries() statement which propagates both include and linking requirements and tends to be the modern CMake practice, although admitedly not very clearly documented in target_link_libraries() official documentation. I found [ https://schneide.blog/2016/04/08/modern-cmake-with-target_link_libraries/ | https://schneide.blog/2016/04/08/modern-cmake-with-target_link_libraries/ ] which deal with that.
So a typical minimum CMakeLists.txt of a project using GDAL is (this is actually [ https://github.com/OSGeo/gdal/blob/master/autotest/postinstall/test_c/CMakeLists.txt | https://github.com/OSGeo/gdal/blob/master/autotest/postinstall/test_c/CMakeLists.txt ] used in GDAL continuous integration to test usage of GDAL from a third-party library/application)
cmake_minimum_required(VERSION 3.0)
project(test_c C CXX) # CXX for properly linking GDAL
find_package(GDAL CONFIG REQUIRED)
target_link_libraries(test_c PRIVATE GDAL::GDAL)
I've created [ https://github.com/OSGeo/gdal/issues/5875 | https://github.com/OSGeo/gdal/issues/5875 ] to track we need documenting that.
Note: If you really wanted to get the equivalent of GDAL_INCLUDE_DIRS and GDAL_LIBRARIES, you could use the following expressions:
$<TARGET_PROPERTY:GDAL::GDAL,INTERFACE_INCLUDE_DIRECTORIES>
$<TARGET_PROPERTY:GDAL::GDAL,INTERFACE_LINK_LIBRARIES>
Even
Le 07/06/2022 à 02:02, Tom O'Reilly a écrit :
BQ_BEGIN
I've just built and installed GDAL 3.5.0 on ubuntu 20.04, with cmake 3.5.0 and make. It appears that 'make install' installs needed cmake config files for GDAL:
BQ_BEGIN
-- Installing: /usr/local/lib/x86_64-linux-gnu/cmake/gdal/GDALConfigVersion.cmake
-- Installing: /usr/local/lib/x86_64-linux-gnu/cmake/gdal/GDALConfig.cmake
BQ_END
I'm building my own project that uses GDAL. The CMakelists.txt invokes find_package() and prints out resulting variables:
BQ_BEGIN
if (GDAL_FOUND)
message("GDAL Found!")
message("GDAL_INCLUDE_DIRS: ${GDAL_INCLUDE_DIRS}")
message("GDAL_LIBRARIES: ${GDAL_LIBRARIES}")
message("GDAL_VERSION: ${GDAL_VERSION}")
else()
message("GDAL not found")
endif()
BQ_END
Running cmake indicates that GDAL_FOUND is true, GDAL_VERSION is set to the expected value(3.5.0), but GDAL_LIBRARIES and GDAL_INCLUDE_DIRS are empty:
BQ_BEGIN
GDAL Found!
GDAL_INCLUDE_DIRS:
GDAL_LIBRARIES:
GDAL_LIBRARY:
GDAL_VERSION: 3.5.0
BQ_END
Why are GDAL_LIBRARIES and GDAL_INCLUDE_DIR empty?
Thanks
Tom
BQ_BEGIN
BQ_END
Thomas C. O'Reilly
7700 Sandholdt Road
831-775-1620 (FAX)
[ mailto:oreilly at mbari.org | oreilly at mbari.org ] (email)
[ http://www.mbari.org/ | http://www.mbari.org ] (World-wide Web)
gdal-dev mailing list [ mailto:gdal-dev at lists.osgeo.org | gdal-dev at lists.osgeo.org ] [ https://lists.osgeo.org/mailman/listinfo/gdal-dev | https://lists.osgeo.org/mailman/listinfo/gdal-dev ]
BQ_END
-- [ http://www.spatialys.com/ | http://www.spatialys.com ] My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220607/6fd5658c/attachment.htm>
