[gdal-dev] Issue defining compound projection with a local projection for GeoTIFF
Even Rouault
even.rouault at spatialys.com
Wed Jun 8 03:38:45 PDT 2022
Chris,
Please file a ticket about that at https://github.com/OSGeo/gdal/issues/new
Even
Le 08/06/2022 à 09:11, Chris Smemoe via gdal-dev a écrit :
> I’m not sure whether this is a bug or some issue with how I’m doing
> things (like maybe my WKT is bogus), but when I try to define a
> compound projection for a GeoTIFF with a local projection, the
> vertical projection information does not get saved to the GeoTIFF and
> I get an error reported from PROJ. I am trying to upgrade the version
> of GDAL I’m using and I think this used to work in GDAL version 2.x
> but no longer works in GDAL 3.x/PROJ 7.x. What I’m trying to do is to
> update the projection of a GeoTIFF from a local projection with
> horizontal units only to a compound projection with both horizontal
> and vertical units. When I close the GDAL dataset, It seems like PROJ
> is trying to look for an ellipsoid node for the spatial reference
> object but I don’t have one since I’m using a local projection. Then
> when I reopen the dataset, nothing seems to have been saved. I’m
> running GDAL 3.4.2. Here’s an example of what I’m trying to do:
> -------------------begin-------------------
> python
> >>> from osgeo import gdal
> >>> gd = gdal.Open("C:\\temp\\grid_meter_exported.tif", gdal.GA_Update)
> >>> gd
> <osgeo.gdal.Dataset; proxy of <Swig Object of type 'GDALDatasetShadow
> *' at 0x000001B6BC578630> >
> >>> gd.GetProjectionRef()
> 'LOCAL_CS["None",UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH]]'
> gd.SetProjection('COMPD_CS["None",LOCAL_CS["None",LOCAL_DATUM["None",32767],UNIT["Foot_US",0.304800609601219],AXIS["None",OTHER]],VERT_CS["Local
> Meter",VERT_DATUM["Local",2005],UNIT["Meter",1,AUTHORITY["EPSG","9001"]],AXIS["Gravity-related
> height",UP]]]')
> 0
> >>> gd.GetProjection()
> height",UP]]]'
> >>> gd = None
> ERROR 1: PROJ: proj_get_ellipsoid: CRS has no geodetic CRS
> ERROR 1: PROJ: proj_get_ellipsoid: Object is not a CRS or
> GeodeticReferenceFrame
> ERROR 1: PROJ: proj_crs_get_geodetic_crs: CRS has no geodetic CRS
> >>> gd
> *' at 0x000001B6BC578720> >
> -------------------end-------------------
> The dataset I’m working with can be downloaded here:
> https://www.dropbox.com/s/2jn7vkcl690e90r/grid_meter_exported.tif?dl=1
> I’d appreciate any guidance.
> Thanks,
> Chris
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220608/cf939ca8/attachment.htm>
