[gdal-dev] ogrinfo UPDATE performance request
Alexandre Gacon alexandre.gacon at gmail.com
Wed Jun 8 23:59:03 PDT 2022
If you work with a Postgres database, why don't you do this directly in the
database? It seems odd to use ogrinfo to do such updates in database.
Regards
Alexandre
Le jeu. 9 juin 2022 à 08:50, Andreas Oxenstierna <
andreas.oxenstierna at t-kartor.com> a écrit :
> Dear developers
> Ogr SQL update capabilities are really impressing but there is one major
> performance issue with update of many features, exemplified by:
> ogrinfo -dialect sqlite -sql "UPDATE <table> SET x = 1" PG:”<connection>"
> This is painfully slow because ogr updates features one by one and
> furthermore updates all existing attributes incl. geometries.
> Eg. updating 10000 features in pgAdmin/psql with UPDATE <table> SET x = 1
> executes in milliseconds but takes several minutes with ogr.
> The current ogr functionality is also not correct from a database
> transactional point of view.
> I found an old RFC,
> https://gdal.org/development/rfc/rfc13_createfeatures.html, requesting
> this but it was withdrawn for reasons not anymore digitally available.
> Best Regards
> Andreas Oxenstierna
> T-Kartor Geospatial AB
> Olof Mohlins väg 12 Kristianstad
> mobile: +46 733 206831
> mailto: andreas.oxenstierna at t-kartor.com
> www.t-kartor.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220609/6c7aa902/attachment.htm>
