[gdal-dev] ogrinfo UPDATE performance request
Jan Heckman jan.heckman at gmail.com
Thu Jun 9 01:17:11 PDT 2022
Afaik as I know, slightly more involved sql on a postgresql table requires
dialect=sqlite to work at all, e.g. (picked a random example using ogr2ogr
instead of ogrinfo)
ogr2ogr -f postgresql -dialect sqlite -append PG:"user=%user%
dbname=%dbname%" -sql "select trim(coalesce(iv1,''),';') as fidstring,
code, st_union(geometry) as multipolygon from alltogether_pruned_out group
by iv1,code" -nln %schema%.%baseout%_pruned -nlt multipolygon
alltogether_pruned_out.shp
This gives me acceptable performance, btw. It's handling a really large
dataset, so having to wait for some minutes did not bother me.
This is on version 3.4.2.
The transaction behavior in ogr2ogr can be influenced with the -gt option,
with -gt unlimited to do everything in a single transaction.
But it would be nice if this imo strange need to refer to dialect sqlite
were removed. Especially strange when you use postgis functions in the sql
statement...
Best regards,
Jan
On Thu, Jun 9, 2022 at 9:46 AM Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Do not use “-dialect sqlite” if you play with PostgreSQL but let GDAL to
> use the native PG SQL dialect.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Andreas
> Oxenstierna
> *Lähetetty:* torstai 9. kesäkuuta 2022 9.50
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] ogrinfo UPDATE performance request
> Dear developers
> Ogr SQL update capabilities are really impressing but there is one major
> performance issue with update of many features, exemplified by:
> ogrinfo -dialect sqlite -sql "UPDATE <table> SET x = 1" PG:”<connection>"
> This is painfully slow because ogr updates features one by one and
> furthermore updates all existing attributes incl. geometries.
> Eg. updating 10000 features in pgAdmin/psql with UPDATE <table> SET x = 1
> executes in milliseconds but takes several minutes with ogr.
> The current ogr functionality is also not correct from a database
> transactional point of view.
> I found an old RFC,
> https://gdal.org/development/rfc/rfc13_createfeatures.html, requesting
> this but it was withdrawn for reasons not anymore digitally available.
> Best Regards
> Andreas Oxenstierna
> T-Kartor Geospatial AB
> Olof Mohlins väg 12 Kristianstad
> mobile: +46 733 206831
> mailto: andreas.oxenstierna at t-kartor.com
> www.t-kartor.com
> <https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.t-kartor.com%2F&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7Ced60af7ce08c45c3998108da49e44745%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C1%7C637903542052214466%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C2000%7C%7C%7C&sdata=UNIxumUx%2BtBz8Vb7jjH3Uvnbjwo3WYvj9tsRmrFHw5g%3D&reserved=0>
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220609/fce61d6c/attachment.htm>
