[gdal-dev] Iterating through an OGR polygon as a set of triangles via the C API
Even Rouault even.rouault at spatialys.com
Fri Jun 10 08:29:27 PDT 2022
Le 10/06/2022 à 17:08, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] via gdal-dev a écrit :
> Hi,
> My goal is to build an indexed list of triangles from OGR polygons as
> inputs to a hardware rasterizer for efficient rendering.  I see RFC 64
> was implemented a few years ago but the documentation warns "not yet
> implemented".
-->where exactly do you see this mentioned?
Anyway, tesselation as triangles wasn't in the scope of the RFC
But you might want to use OGR_G_DelaunayTriangulation()
> These is reinforced by my failed attempt to use OGR_G_ForceTo on a
> polygon geometry to the TIN type.  OGR's object hierarchy can be easy
> to misunderstand so maybe I'm just missing something here.
> Is this functionality available? If not, are viewers like QGIS
> manually building an index list themselves (or perhaps they use old
> fixed function APIs)?
> Thanks,
> Jesse
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220610/58e55f82/attachment-0001.htm>
