[gdal-dev] Proposed new driver to handle Basis Universal / KTX2 textures
Even Rouault
even.rouault at spatialys.com
Thu Jun 16 12:15:38 PDT 2022
Jean-Roc,
those formats have potential to be loaded on the GPU with very few
processing, as far as I understand their description. And the
BinomialLLC/basis_universal code is able to do that typically.
That said in a GDAL context, full decompression/compression will be done
as there's no direct interface between GDAL and the GPU. The use case
here is more to use GDAL's convenient generic raster capabilities to
read/write that format amongst other textures formats (which don't hold
georefencing by themselves, but may be associated to georeferenced
objects externally), regular non-georeferenced images ... and sometimes
geospatial raster formats.
Even
Le 16/06/2022 à 20:46, Jean-Roc Morreale (ml) a écrit :
> Hi Even,
> Out of curiosity, what are the possible usecases for geospatial tasks,
> georeferenced normal/displacement mapping straight to the gpu ?
> regards,
> JR
> Le mercredi 15 juin 2022 à 16:51 +0200, Even Rouault a écrit :
>> Hi,
>> There's interest for adding a new read/write raster GDAL driver for
>> the
>> Basis Universal and KTX2
>> (https://github.khronos.org/KTX-Specification/)
>> texture formats, used in 3D/BIM formats like I3S and glTF. That would
>> use the https://github.com/BinomialLLC/basis_universal software
>> (Apache
>> 2.0 licensed) to do the encoding/decoding.
>> I just wanted to know if people were comfortable to have this as a
>> in-tree (optional) GDAL driver. Texture support is not necessarily
>> where
>> GDAL is most known but we do already have a few drivers specifically
>> handling that like the DDS/crunch one
>> (https://gdal.org/drivers/raster/dds.html) or the TARGA one
>> (https://gdal.org/drivers/raster/tga.html), not mentioning more
>> generic
>> purposes formats like JPEG or PNG.
>> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
