[gdal-dev] gdalwarp Resampling Input Raster Nodata Setting
    Chao Li
    chaoli0394 at gmail.com
    Sun Jun 26 18:08:52 PDT 2022
Dear GDAL experts,
I have a problem using *gdalwarp*.
I want to reproject a raster and change its resolution by the average
method.
This is the *gdalinfo* of the raster
[q70176a at ito-2 ~]$ gdalinfo
 DP12/11_RawData/02_GGP/Gross_PP_8Days_500m_v6/GPP/MOD17A2H_GPP_2016_001.tif
                                                      Driver: GTiff/GeoTIFF
Files:
Size is 86400, 31200
Coordinate System is:
PROJCRS["unknown",
    BASEGEOGCRS["unknown",
        DATUM["unknown",
            ELLIPSOID["unknown",6371007.181,0,
                LENGTHUNIT["metre",1,
                    ID["EPSG",9001]]]],
        PRIMEM["Greenwich",0,
            ANGLEUNIT["degree",0.0174532925199433,
                ID["EPSG",9122]]]],
    CONVERSION["Sinusoidal",
        METHOD["Sinusoidal"],
        PARAMETER["Longitude of natural origin",0,
            ANGLEUNIT["degree",0.0174532925199433],
            ID["EPSG",8802]],
        PARAMETER["False easting",0,
            LENGTHUNIT["metre",1],
            ID["EPSG",8806]],
        PARAMETER["False northing",0,
            ID["EPSG",8807]]],
    CS[Cartesian,2],
        AXIS["easting",east,
            ORDER[1],
                ID["EPSG",9001]]],
        AXIS["northing",north,
            ORDER[2],
                ID["EPSG",9001]]]]
Data axis to CRS axis mapping: 1,2
Origin = (-20015109.353999998420477,7783653.637667000293732)
Pixel Size = (463.312716527771215,-463.312716527787586)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-20015109.354, 7783653.638) (166d17' 5.25"W, 70d 0' 0.00"N)
Lower Left  (-20015109.354,-6671703.118) (  0d 0' 0.00"E, 60d 0' 0.00"S)
Upper Right (20015109.354, 7783653.638) (166d17' 5.25"E, 70d 0' 0.00"N)
Lower Right (20015109.354,-6671703.118) (  0d 0' 0.00"W, 60d 0' 0.00"S)
Center      (      -0.000,  555975.260) (  0d 0' 0.00"W,  5d 0' 0.00"N)
Band 1 Block=86400x1 Type=Int16, ColorInterp=Gray
  NoData Value=32767
This is the *gdalwarp* commend:
[q70176a at ito-2 ~]$ gdalwarp -t_srs EPSG:4326 -te -180 -90 180  90 -tr 0.1
0.1 -ot Float64 -r average -srcnodata "32767" -multi -overwrite
DP12/11_RawData/02_GGP/Gross_PP_8Days_500m_v6/GPP_01_test/test2.tif
I also tried
0.1 -ot Float64 -r average -srcnodata 32767 -multi -overwrite
However, the 32767 is not set to be nodata, and be averaged in the output
raster.
How can I set this?
Additionally, I am using a HPC with multinodes. With 8 nodes, I have 288.
If I set -multi and -wo NUM_THREADS=val/ALL_CPUS, will all that 288 run
together?
Since there nothing returns, I really do not know.
Best regards.
Mike Li
Department of Urban and Environmental Engineering
Graduate School of Engineering
Kyushu University
744 Motooka, Nishi-ku, Fukuoka 819-0395 Japan
Tel: 090-8304-8953
E-mail: chaoli0394 at gmail.com
李潮(リ チョウ)
九州大学 大学院 工学府 都市環境システム工学専攻
都市工学研究室
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220627/562dcc37/attachment.htm>
