[gdal-dev] gdalwarp Resampling Input Raster Nodata Setting
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Mon Jun 27 01:17:31 PDT 2022
It seems to work for me with GDAL 3.6.0dev on Windows.
gdalwarp -t_srs EPSG:4326 -r average -ot float64 -multi MOD17A2H_GPP_2020_001.tif mod64m.tif
Creating output file that is 2969P x 2572L.
Processing MOD17A2H_GPP_2020_001.tif [1/1] : 0Using internal nodata values (e.g. 32767) for image MOD17A2H_GPP_2020_001.tif.
Copying nodata values from source MOD17A2H_GPP_2020_001.tif to destination mod64m.tif.
...10...20...30...40...50...60...70...80...90...100 - done.
gdalinfo mod64m.tif
Driver: GTiff/GeoTIFF
Files: mod64m.tif
Size is 2969, 2572
Coordinate System is:
GEOGCRS["WGS 84",
Band 1 Block=2969x1 Type=Float64, ColorInterp=Gray
NoData Value=32767
I don’t know why nodata is lost for you. Have you already tried to set the output nodata explicitly with -dstnodata 32767 as a workaround?
-Jukka Rahkonen-
Lähettäjä: Chao Li <chaoli0394 at gmail.com>
Lähetetty: maanantai 27. kesäkuuta 2022 10.50
Vastaanottaja: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: Re: [gdal-dev] gdalwarp Resampling Input Raster Nodata Setting
Dear Ms./Mr. Jukka
Thank you for your reply. I try to delete the -srcnodata 32767, but it still doesn't work.
I have attach a part of raster, in this email.
Thanks for your help
Best regards
Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> 于2022年6月27日周一 14:52写道:
The right syntax is average -srcnodata 32767 but you should not need to use it at all because GDAL recognizes nodata from your input automatically as you can see from the gdalinfo report. Could you clip and share a small sample from your source data so that some nodata is included? You can use gdal_translate with -srswin or -projwin for that.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> Puolesta Chao Li
Lähetetty: maanantai 27. kesäkuuta 2022 4.09
Vastaanottaja: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] gdalwarp Resampling Input Raster Nodata Setting
Dear GDAL experts,
I have a problem using gdalwarp.
I want to reproject a raster and change its resolution by the average method.
This is the gdalinfo of the raster
[q70176a at ito-2 ~]$ gdalinfo DP12/11_RawData/02_GGP/Gross_PP_8Days_500m_v6/GPP/MOD17A2H_GPP_2016_001.tif Driver: GTiff/GeoTIFF
Files: DP12/11_RawData/02_GGP/Gross_PP_8Days_500m_v6/GPP/MOD17A2H_GPP_2016_001.tif
Size is 86400, 31200
PROJCRS["unknown",
BASEGEOGCRS["unknown",
DATUM["unknown",
ELLIPSOID["unknown",6371007.181,0,
LENGTHUNIT["metre",1,
ID["EPSG",9001]]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433,
ID["EPSG",9122]]]],
CONVERSION["Sinusoidal",
METHOD["Sinusoidal"],
PARAMETER["Longitude of natural origin",0,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8802]],
PARAMETER["False easting",0,
LENGTHUNIT["metre",1],
ID["EPSG",8806]],
PARAMETER["False northing",0,
ID["EPSG",8807]]],
CS[Cartesian,2],
AXIS["easting",east,
ORDER[1],
ID["EPSG",9001]]],
AXIS["northing",north,
ORDER[2],
ID["EPSG",9001]]]]
Data axis to CRS axis mapping: 1,2
Origin = (-20015109.353999998420477,7783653.637667000293732)
Pixel Size = (463.312716527771215,-463.312716527787586)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-20015109.354, 7783653.638) (166d17' 5.25"W, 70d 0' 0.00"N)
Lower Left (-20015109.354,-6671703.118) ( 0d 0' 0.00"E, 60d 0' 0.00"S)
Upper Right (20015109.354, 7783653.638) (166d17' 5.25"E, 70d 0' 0.00"N)
Lower Right (20015109.354,-6671703.118) ( 0d 0' 0.00"W, 60d 0' 0.00"S)
Center ( -0.000, 555975.260) ( 0d 0' 0.00"W, 5d 0' 0.00"N)
Band 1 Block=86400x1 Type=Int16, ColorInterp=Gray
NoData Value=32767
This is the gdalwarp commend:
[q70176a at ito-2 ~]$ gdalwarp -t_srs EPSG:4326 -te -180 -90 180 90 -tr 0.1 0.1 -ot Float64 -r average -srcnodata "32767" -multi -overwrite DP12/11_RawData/02_GGP/Gross_PP_8Days_500m_v6/GPP/MOD17A2H_GPP_2016_001.tif DP12/11_RawData/02_GGP/Gross_PP_8Days_500m_v6/GPP_01_test/test2.tif
I also tried
[q70176a at ito-2 ~]$ gdalwarp -t_srs EPSG:4326 -te -180 -90 180 90 -tr 0.1 0.1 -ot Float64 -r average -srcnodata 32767 -multi -overwrite DP12/11_RawData/02_GGP/Gross_PP_8Days_500m_v6/GPP/MOD17A2H_GPP_2016_001.tif DP12/11_RawData/02_GGP/Gross_PP_8Days_500m_v6/GPP_01_test/test2.tif
However, the 32767 is not set to be nodata, and be averaged in the output raster.
How can I set this?
Additionally, I am using a HPC with multinodes. With 8 nodes, I have 288. If I set -multi and -wo NUM_THREADS=val/ALL_CPUS, will all that 288 run together?
Since there nothing returns, I really do not know.
Best regards.
Mike Li
Department of Urban and Environmental Engineering
Graduate School of Engineering
Kyushu University
744 Motooka, Nishi-ku, Fukuoka 819-0395 Japan
Tel: 090-8304-8953
E-mail: chaoli0394 at gmail.com<mailto:chaoli0394 at gmail.com>
李潮(リ チョウ)
九州大学 大学院 工学府 都市環境システム工学専攻
都市工学研究室
Mike Li
Kyushu University
Tel: 090-8304-8953
李潮(リ チョウ)
都市工学研究室
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220627/3e1b6e48/attachment-0001.htm>
