[gdal-dev] gdalwarp Resampling Input Raster Nodata Setting
Chao Li chaoli0394 at gmail.com
Mon Jun 27 03:55:20 PDT 2022
You are right but when I try to check the data processing, there is no any
compression. On my computer, it is similar to your situation. I guess most
nodata values are over 32760, so maybe I can list all of them.
-srcnodata <32760 32761 32762 32763 32764 32765 32766 32767>. Is this the
right way?
Thank you.
Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi> 于2022年6月27日周一 18:14写道:
> Hi,
> Please send answers as reply-to-all so they will go also to the gdal-dev
> mailing list.
> There is something odd in the source data. As you can see from the
> attached image there are pixels which are close to the nodata 32767 but
> not exactly. Huge areas have value 32766 but here and there I can also see
> values 32765, 32762 etc.  The point in the image is at EPSG:4326
> 97.30902,5.18109.
> I think that the source data that you clipped for the test is somehow
> corrupted. Could you check if you can find similar pixel values from the
> original image? The sample is LZW compressed but could it be that at some
> moment the image has been compressed with JPEG or some other lossy method?
> -Jukka Rahkonen-
> *Lähettäjä:* Chao Li <chaoli0394 at gmail.com>
> *Lähetetty:* maanantai 27. kesäkuuta 2022 11.29
> *Vastaanottaja:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
> *Aihe:* Re: [gdal-dev] gdalwarp Resampling Input Raster Nodata Setting
> Hi,
> Now, seemingly, it works. I am also able to get output raster, but once
> you visualize this raster you will find that the boundaries between value
> and nodata zones are abnormal. There might be over 20,000.
> However the valid values are no more than 1000. That’s my problem.
> Could please check whether you have the same problem?
> Thank you.
> Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>于2022年6月27日 周一17:17写道:
> Hi,
> It seems to work for me with GDAL 3.6.0dev on Windows.
> gdalwarp -t_srs EPSG:4326 -r average -ot float64 -multi
> MOD17A2H_GPP_2020_001.tif mod64m.tif
> Creating output file that is 2969P x 2572L.
> Processing MOD17A2H_GPP_2020_001.tif [1/1] : 0Using internal nodata values
> (e.g. 32767) for image MOD17A2H_GPP_2020_001.tif.
> Copying nodata values from source MOD17A2H_GPP_2020_001.tif to destination
> mod64m.tif.
> ...10...20...30...40...50...60...70...80...90...100 - done.
> gdalinfo mod64m.tif
> Driver: GTiff/GeoTIFF
> Files: mod64m.tif
> Size is 2969, 2572
> Coordinate System is:
> GEOGCRS["WGS 84",
> Band 1 Block=2969x1 Type=Float64, ColorInterp=Gray
>   NoData Value=32767
> I don’t know why nodata is lost for you. Have you already tried to set the
> output nodata explicitly with -dstnodata 32767 as a workaround?
> -Jukka Rahkonen-
> *Lähetetty:* maanantai 27. kesäkuuta 2022 10.50
> Dear Ms./Mr. Jukka
> Thank you for your reply. I try to delete the  -srcnodata 32767, but it
> still doesn't work.
> I have attach a part of raster, in this email.
> Thanks for your help
> Best regards
> Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi> 于2022年6月27日周一 14:52
> 写道:
> Hi,
> The right syntax is average -srcnodata 32767 but you should not need to
> use it at all because GDAL recognizes nodata from your input automatically
> as you can see from the gdalinfo report. Could you clip and share a small
> sample from your source data so that some nodata is included? You can use
> gdal_translate with -srswin or -projwin for that.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Chao
> Li
> *Lähetetty:* maanantai 27. kesäkuuta 2022 4.09
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] gdalwarp Resampling Input Raster Nodata Setting
> Dear GDAL experts,
> I have a problem using *gdalwarp*.
> I want to reproject a raster and change its resolution by the average
> method.
> This is the *gdalinfo* of the raster
> [q70176a at ito-2 ~]$ gdalinfo
>  DP12/11_RawData/02_GGP/Gross_PP_8Days_500m_v6/GPP/MOD17A2H_GPP_2016_001.tif
> Files:
> Size is 86400, 31200
> PROJCRS["unknown",
>     BASEGEOGCRS["unknown",
>         DATUM["unknown",
>             ELLIPSOID["unknown",6371007.181,0,
>                 LENGTHUNIT["metre",1,
>                     ID["EPSG",9001]]]],
>         PRIMEM["Greenwich",0,
>             ANGLEUNIT["degree",0.0174532925199433,
>                 ID["EPSG",9122]]]],
>     CONVERSION["Sinusoidal",
>         METHOD["Sinusoidal"],
>         PARAMETER["Longitude of natural origin",0,
>             ANGLEUNIT["degree",0.0174532925199433],
>             ID["EPSG",8802]],
>         PARAMETER["False easting",0,
>             LENGTHUNIT["metre",1],
>             ID["EPSG",8806]],
>         PARAMETER["False northing",0,
>             ID["EPSG",8807]]],
>     CS[Cartesian,2],
>         AXIS["easting",east,
>             ORDER[1],
>                 ID["EPSG",9001]]],
>         AXIS["northing",north,
>             ORDER[2],
>                 ID["EPSG",9001]]]]
> Data axis to CRS axis mapping: 1,2
> Origin = (-20015109.353999998420477,7783653.637667000293732)
> Pixel Size = (463.312716527771215,-463.312716527787586)
> Metadata:
>   AREA_OR_POINT=Area
> Image Structure Metadata:
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (-20015109.354, 7783653.638) (166d17' 5.25"W, 70d 0' 0.00"N)
> Lower Left  (-20015109.354,-6671703.118) (  0d 0' 0.00"E, 60d 0' 0.00"S)
> Upper Right (20015109.354, 7783653.638) (166d17' 5.25"E, 70d 0' 0.00"N)
> Lower Right (20015109.354,-6671703.118) (  0d 0' 0.00"W, 60d 0' 0.00"S)
> Center      (      -0.000,  555975.260) (  0d 0' 0.00"W,  5d 0' 0.00"N)
> Band 1 Block=86400x1 Type=Int16, ColorInterp=Gray
>   NoData Value=32767
> This is the *gdalwarp* commend:
> [q70176a at ito-2 ~]$ gdalwarp -t_srs EPSG:4326 -te -180 -90 180  90 -tr 0.1
> 0.1 -ot Float64 -r average -srcnodata "32767" -multi -overwrite
> DP12/11_RawData/02_GGP/Gross_PP_8Days_500m_v6/GPP_01_test/test2.tif
> I also tried
> 0.1 -ot Float64 -r average -srcnodata 32767 -multi -overwrite
> However, the 32767 is not set to be nodata, and be averaged in the output
> raster.
> How can I set this?
> Additionally, I am using a HPC with multinodes. With 8 nodes, I have 288.
> If I set -multi and -wo NUM_THREADS=val/ALL_CPUS, will all that 288 run
> together?
> Since there nothing returns, I really do not know.
> Best regards.
> Mike Li
> Department of Urban and Environmental Engineering
> Graduate School of Engineering
> Kyushu University
> 744 Motooka, Nishi-ku, Fukuoka 819-0395 Japan
> Tel: 090-8304-8953
> E-mail: chaoli0394 at gmail.com
> 李潮(リ チョウ)
> 九州大学 大学院 工学府 都市環境システム工学専攻
> 都市工学研究室
> Mike Li
> Kyushu University
> Tel: 090-8304-8953
> 李潮(リ チョウ)
> 都市工学研究室
> Mike Li
> Kyushu University
> Tel: 090-8304-8953
> 李潮(リ チョウ)
> 都市工学研究室
Mike Li
Kyushu University
Tel: 090-8304-8953
李潮(リ チョウ)
都市工学研究室
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220627/b12ba6c9/attachment-0001.htm>
