[gdal-dev] Fwd: Creating MBTiles with transparent background from GeoTIFF
Kanishk Varshney
varskann1993 at gmail.com
Mon Jun 27 05:21:43 PDT 2022
Hey all,
I am stuck with MBTiles creation from GeoTIFF files that have a black
background (RGB: 0,0,0).
In QGIS, I am able to generate MBTiles via the following steps:
- Set Transparency pixel (0 0 0) to get a geotiff with transparent
background
- Use Generate XYZ tiles (MBTiles) tool to generate the MBTiles for the
above generated geotiff.
I want to automate the workflow using python, but not able to achieve great
success.
The following commands are used:
gdal_translate -tr 0.035 0.035 -a_nodata none -of MBTILES file1.tif
file1.mbtiles
gdaladdo -r nearest file1.mbtiles 2 4 8 16
This results in following issues:
1. The generated mbtiles don't have all the resolutions that manually
generated MBTiles have
2. Background is still black, which is a big concern for my usecase
Any help or alternative would be appreciated. Attaching a sample
Geotiff for reference
sample_geotiff.tif
<https://drive.google.com/file/d/1HJaw59FVEwG_9sEN8bvfeRw1GrawGnUb/view?usp=drive_web>
Thanks,
Kanishk
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220627/94dd2061/attachment.htm>
