[gdal-dev] gdal_calc.py Does Not Work on Mac
Chao Li
chaoli0394 at gmail.com
Mon Jun 27 20:18:47 PDT 2022
I meet a problem when I use gdal_calc.py on mac:
(base) lichao at riushios-MacBook-Pro ~ % gdal_calc.py
File
"/Users/lichao/opt/anaconda3/lib/python3.9/site-packages/osgeo/__init__.py",
line 29, in swig_import_helper
return importlib.import_module(mname)
File "/Users/lichao/opt/anaconda3/lib/python3.9/importlib/__init__.py",
line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 666, in _load_unlocked
File "<frozen importlib._bootstrap>", line 565, in module_from_spec
File "<frozen importlib._bootstrap_external>", line 1173, in create_module
File "<frozen importlib._bootstrap>", line 228, in
_call_with_frames_removed
ImportError:
dlopen(/Users/lichao/opt/anaconda3/lib/python3.9/site-packages/osgeo/_
gdal.cpython-39-darwin.so, 0x0002): Library not loaded:
@rpath/libpoppler.91.dylib
Referenced from: /Users/lichao/opt/anaconda3/lib/libgdal.30.dylib
Reason: tried: '/Users/lichao/opt/anaconda3/lib/libpoppler.91.dylib' (no
such file), '/Users/lichao/opt/anaconda3/lib/libpoppler.91.dylib' (no such
file),
'/Users/lichao/opt/anaconda3/lib/python3.9/site-packages/osgeo/../../../libpoppler.91.dylib'
(no such file), '/Users/lichao/opt/anaconda3/lib/libpoppler.91.dylib' (no
file),
such file), '/Users/lichao/opt/anaconda3/bin/../lib/libpoppler.91.dylib'
(no such file), '/usr/local/lib/libpoppler.91.dylib' (no such file),
'/usr/lib/libpoppler.91.dylib' (no such file)
During handling of the above exception, another exception occurred:
File "/Users/lichao/opt/anaconda3/bin/gdal_calc.py", line 4, in <module>
__import__('pkg_resources').run_script('GDAL==3.4.1', 'gdal_calc.py')
File
"/Users/lichao/opt/anaconda3/lib/python3.9/site-packages/pkg_resources/__init__.py",
line 662, in run_script
self.require(requires)[0].run_script(script_name, ns)
File
line 1459, in run_script
exec(code, namespace, namespace)
File
"/Users/lichao/opt/anaconda3/lib/python3.9/site-packages/GDAL-3.4.1-py3.9-macosx-10.9-x86_64.egg-info/scripts/gdal_calc.py",
line 5, in <module>
from osgeo_utils.gdal_calc import * # noqa
File
"/Users/lichao/opt/anaconda3/lib/python3.9/site-packages/osgeo_utils/gdal_calc.py",
line 46, in <module>
from osgeo import gdal
File
line 45, in <module>
_gdal = swig_import_helper()
File
line 42, in swig_import_helper
return importlib.import_module('_gdal')
ModuleNotFoundError: No module named '_gdal'
(base) lichao at riushios-MacBook-Pro ~ % which gdal_calc.py
(base) lichao at riushios-MacBook-Pro ~ % gdal-config --version
3.4.1
Thanks for your help.
Best
Mike Li
Department of Urban and Environmental Engineering
Graduate School of Engineering
Kyushu University
744 Motooka, Nishi-ku, Fukuoka 819-0395 Japan
Tel: 090-8304-8953
E-mail: chaoli0394 at gmail.com
李潮(リ チョウ)
九州大学 大学院 工学府 都市環境システム工学専攻
都市工学研究室
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220628/28e54f14/attachment-0001.htm>
