[gdal-dev] Attempting a coherent CMAKE problem report from a git clone- steps taken
Even Rouault
even.rouault at spatialys.com
Sun Mar 6 10:50:04 PST 2022
Le 05/03/2022 à 06:30, chris english a écrit :
> Kai,
> Rebuilt Geos with your insight, and two spaces between all -D entries,
> including eliminating MrSid that was complied under gcc 521 or so and
> might likely cause problems, using GDAL build hints
> <https://gdal.org/build_hints.html>, and we have success on on *target
> gcore_mdreader*, and I'll move on to sorting out what is wrong with
> missing symbols in whatever provides 'nc_open_mem', viz:
> [ 89%] Built target gcore_mdreader
> [ 89%] Linking CXX shared library libgdal.so
> /usr/bin/ld:
> frmts/netcdf/CMakeFiles/gdal_netCDF.dir/netcdfdataset.cpp.o: in
> function `netCDFDataset::Open(GDALOpenInfo*)':
> netcdfdataset.cpp:(.text+0x283d4): undefined reference to `nc_open_mem'
> /usr/bin/ld: netcdfdataset.cpp:(.text+0x2852a): undefined reference to
> `nc_open_mem'
nc_open_mem is provided by the netCDF library. Your issue might come
perharps from doing an initial cmake run with some netCDF version that
includes that symbol , and re-running with an older one that hasn't it,
and then cmake is confused becaused it has kept in cache that the netCDF
lib has the nc_open_mem symbol. Removing CMakeCache.txt and re-running
would solve it.
> Looks like updating libnetcdf...or perhaps not netcdf won't play nice
> with hdf5-1.12.1 till 4.9 dist release
> <https://github.com/Unidata/netcdf-c/issues/2166> so drop netcdf for now.
> And have to figure out turning off DODs, but wow, spotting a missing
> space, I'd have to perl that or something. But, have now arrived at:
Which version of libdap do you use ? Note that support for DODS is
likely to be dropped as we lack maintainers for it (see
https://github.com/OSGeo/gdal/issues/5173)
> [ 86%] Built target gcore_mdreader
> [ 86%] Linking CXX shared library libgdal.so
> /usr/bin/ld: frmts/dods/CMakeFiles/gdal_DODS.dir/dodsdataset2.cpp.o:
> in function `get_variable(libdap::DDS&,
> std::__cxx11::basic_string<char, std::char_traits<char>,
> std::allocator<char> > const&)':
> dodsdataset2.cpp:(.text+0x624): undefined reference to
> `libdap::www2id(std::__cxx11::basic_string<char,
> std::char_traits<char>, std::allocator<char> > const&,
> std::allocator<char> > const&, std::__cxx11::basic_string<char,
> std::char_traits<char>, std::allocator<char> > const&)' <------snip
> and appears -DGDAL_ENABLE_DRIVER_DODS:BOOL=OFF is not doing it.
That's weird... Note that there's also a OGR DODS driver, so to fully
remove any DODS support -DOGR_ENABLE_DRIVER_DODS:BOOL=OFF would be
needed too
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220306/7883e933/attachment-0001.html>
