[gdal-dev] GDAL 3.4.2 RC2 available
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Mar 9 12:06:51 PST 2022
On 2022-03-09 4:05 p.m., Jeff McKenna wrote:
> On 2022-03-09 4:02 p.m., Even Rouault wrote:
>> Le 09/03/2022 à 20:53, Jeff McKenna a écrit :
>>> Thanks Even. RC2 works well on Windows in the MS4W build
>>> environment. The only issue was that I had to re-apply the patch for
>>> Poppler 22.x (this is the known issue of course, that is well
>>> discussed
>>> https://lists.osgeo.org/pipermail/gdal-dev/2022-March/055529.html )
>> Which patch did you need re-apply ? The ones of master are normally
>> included in 3.4.2 :
>> https://github.com/OSGeo/gdal/commit/2d5f96f233e6bda613e98e056bb9a39d12409e32
>> https://github.com/OSGeo/gdal/commit/cbcfe2c8c5507ea00ef7371029ff94d0bf6f4a77
>> . But for nmake based builds, you perhaps need to add a /std:c++17
>> switch to the POPPLER_CFLAGS variable (PS: the benefit of the CMake
>> based builds where a single CMake command can be used to bump to c++17
>> for all platforms is obvious here)
> My builds are CMake, and that was the exact patch I've been applying to
> the POPPLER_EXTRAFLAGS, you're correct. After that, CMake runs fine for
> me.
Ah sorry you're 100% correct, this was not with CMake, it was an nmake
build. Sorry (I was testing GeoTIFF with CMake minutes before this,
confusing my brain ha).
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
