[gdal-dev] OGRCreateCoordinateTransformation()
Even Rouault even.rouault at spatialys.com
Fri Mar 18 15:05:27 PDT 2022
Steve,
Fix in PROJ queued in https://github.com/OSGeo/PROJ/pull/3123
The complexity of dealing with legacy features TOWGS84[] and PROJ4_GRIDS
is highly stressing PROJ pipeline computation engine.
Using the plain EPSG codes  EPSG:4955 -> EPSG:4617+5713 would be much
preferable here
Even
Le 18/03/2022 à 21:14, Steve Riddell a écrit :
> Hi,
> I’m getting an error (below) using GDAL trying to set up a
> transformation between NAD83(CSRS) geodetic, w/ ellipsoidal heights,
> and NAD83(CSRS) geodetic, CGVD28 heights. Similar transformations work
> fine on some datums,  but fail on others.  Hope someone can offer some
> insight.  Note the if I don't use the PROJ4_GRIDS extension, I don't
> get the error, but I don't get the geoid adjustment either.
> COMPD_CS["NAD83(CSRS) + Ellipsoid (Meters)",
>     GEOGCS["NAD83(CSRS)",
> DATUM["NAD83_Canadian_Spatial_Reference_System",
>             SPHEROID["GRS 1980",6378137,298.257222101,
>                 AUTHORITY["EPSG","7019"]],
>             TOWGS84[0,0,0,0,0,0,0],
>             AUTHORITY["EPSG","6140"]],
>         PRIMEM["Greenwich",0,
>             AUTHORITY["EPSG","8901"]],
>         UNIT["degree",0.0174532925199433,
>             AUTHORITY["EPSG","9122"]],
>         AUTHORITY["EPSG","4617"]],
>     VERT_CS["Ellipsoid (Meters)",
>         VERT_DATUM["Ellipsoid",2002],
>         UNIT["metre",1,
>             AUTHORITY["EPSG","9001"]],
>         AXIS["ellipsoidal height",UP]]]
> COMPD_CS["NAD83(CSRS) + CGVD28 height - HT2_0",
>     VERT_CS["CGVD28 height - HT2_0",
>         VERT_DATUM["Canadian Geodetic Vertical Datum of 1928",2005,
> EXTENSION["PROJ4_GRIDS","HT2_0.gtx"],
>             AUTHORITY["EPSG","5114"]],
>         UNIT["metre",1,
>         AXIS["Gravity-related height",UP],
>         AUTHORITY["EPSG","5713"]]]
> ERROR 6: Cannot find coordinate operations from `EPSG:4955' to
> `COMPOUNDCRS["NAD83(CSRS) + CGVD28 height -
> HT2_0",BOUNDCRS[SOURCECRS[GEOGCRS["NAD83(CSRS)",DATUM["NAD83 Canadian
> Spatial Reference System",ELLIPSOID["GRS
> 1980",6378137,298.257222101,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,2],AXIS["geodetic
> latitude
> (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic
> longitude
> (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4617]]],TARGETCRS[GEOGCRS["WGS
> 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS
> 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,2],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]]],ABRIDGEDTRANSFORMATION["Transformation
> from NAD83(CSRS) to WGS84",METHOD["Position Vector transformation
> (geog2D domain)",ID["EPSG",9606]],PARAMETER["X-axis
> translation",0,ID["EPSG",8605]],PARAMETER["Y-axis
> translation",0,ID["EPSG",8606]],PARAMETER["Z-axis
> translation",0,ID["EPSG",8607]],PARAMETER["X-axis
> rotation",0,ID["EPSG",8608]],PARAMETER["Y-axis
> rotation",0,ID["EPSG",8609]],PARAMETER["Z-axis
> rotation",0,ID["EPSG",8610]],PARAMETER["Scale
> difference",1,ID["EPSG",8611]]]],BOUNDCRS[SOURCECRS[VERTCRS["CGVD28
> height - HT2_0",VDATUM["Canadian Geodetic Vertical Datum of
> 1928"],CS[vertical,1],AXIS["gravity-related
> height",up,LENGTHUNIT["metre",1]],ID["EPSG",5713]]],TARGETCRS[GEOGCRS["WGS
> 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal
> height",up,ORDER[3],LENGTHUNIT["metre",1]],ID["EPSG",4979]]],ABRIDGEDTRANSFORMATION["CGVD28
> height - HT2_0 to WGS84 ellipsoidal
> height",METHOD["GravityRelatedHeight to
> Geographic3D"],PARAMETERFILE["Geoid (height correction) model
> file","HT2_0.gtx",ID["EPSG",8666]]]]]'
> Thanks in advance for any assistance! Best regards,
> Steve
> Steve Riddell
> Software Engineering
> *GeoCue Group, Inc.*
> 520 6th Street | Madison, AL 35756 USA**
> *Phone:*256.461.8289 | *Fax:* 256.461.8249
> /LIDAR/Drone Mapping Software & Services //– //True View® 3D Imaging
> Sensors //–//Image/LIDAR Data Management Solutions///
> www.geocue.com <http://www.geocue.com/>support.geocue.com
> <https://support.geocue.com/>
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220318/9eae3de6/attachment.html>
