[gdal-dev] Is PAM always used before GeoTIFF tags?
Even Rouault
even.rouault at spatialys.com
Tue Mar 22 07:04:29 PDT 2022
Jukka,
Le 22/03/2022 à 12:56, Rahkonen Jukka (MML) a écrit :
> Hi,
> See this question
> https://gis.stackexchange.com/questions/426418/create-rectified-geotiff-given-aux-xml-produced-from-arcgis?
> The GeoTIFF driver documentation
> https://gdal.org/drivers/raster/gtiff.html#georeferencing says about
> the order in which the georeferencing is searched “By default,
> information is fetched in following order (first listed is the most
> prioritary): PAM (Persistent Auxiliary metadata) .aux.xml sidecar
> file, INTERNAL (GeoTIFF keys and tags), TABFILE (.tab), WORLDFILE
> (.tfw, .tifw/.tiffw or .wld).”
> However, in this case it seems that GeoTIFF tags are used instead of
> PAM if not especially asked with --config GDAL_GEOREF_SOURCES PAM
Yes I can see in the code that for that particular case with standard
TIFF tags expressing a geotransform (which is completely buggy on the
sample file of the stackexchange thread) an this ESRI GeodataXform
.aux.xml stuff, both will be reported. I've just fixed this in
https://github.com/OSGeo/gdal/commit/acbd907896418330315f3e6febf620d4686023ac
Adding -to SRC_METHOD=GCP_POLYNOMIAL or GCP_TPS to gdalwarp will force
the GCPs to be used.
> I am also curious to know how the SourceGCP values in this PAM file
> gets converted into pixel rows and columns. For example these values
> <SourceGCPs xsi:type="typens:ArrayOfDouble">
> <Double>3.3670799903498199</Double>
> <Double>14.344873843184562</Double>
> seem to turn into (1010.12399710495,3376.53784704463). How does it
> happen and where is it documented? I think there must happen some
> scaling and offsetting but is this something ESRI specific? I found
> this ESRI document but there the columns and rows appear unscaled in
> the aux.xml file
> https://doc.arcgis.com/en/imagery/workflows/browse-imagery/workflow/workflow-appendices.htm.
I see support for the ESRI GeodataXform .aux.xml stuff was added in
https://github.com/OSGeo/gdal/commit/7025e356c28
The interesting part to explain the difference between the values in the
files and the ones reported by gdalinfo is in:
+ // The origin used is the bottom left corner,
+ // and raw values are in inches !
+ pasGCPList[i].dfGCPPixel = adfSourceGCPs[2*i] *
+ CPLAtof(pszTIFFTagXRes);
+ pasGCPList[i].dfGCPLine = nRasterYSize -
+ adfSourceGCPs[2*i+1] *
CPLAtof(pszTIFFTagYRes);
At least this was found to be necessary on the sample file that was used
to develop this code. And actually trying with the file in the
stackexchange thread, this leads to correct georeferencing.
Even
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220322/55e48153/attachment.html>
