[gdal-dev] OGR Style is null for Geometry Collections
Jacky Tang jtang at nltinc.com.au
Tue Mar 22 17:30:52 PDT 2022
Jacky Tang <jtang at nltinc.com.au>
08:29 (2 hours ago)
to gdal-dev
Hello,
I am having some issues retrieving the OGR style with ogr2ogr for geometry
collections, as it returns null and the geometries themselves do not
include OGR style. Any assistance would be greatly appreciated!
ogr2ogr
  -f geojson
  -s_srs "EPSG:2000"
  -t_srs "EPSG:4326"
  -dialect sqlite -sql "select layer, geometry, ogr_style from entities"
  -lco RFC7946=YES
  -skipfailures
  "map.geojson"
  "map.dwg"
I have also tried `select *, ogr_style` with no luck either.
Example output GeometryCollection:
    "type": "Feature",
    "properties": {
        "Layer": "1",
        "OGR_STYLE": null
    "geometry": {
        "type": "GeometryCollection",
        "geometries": [
                "type": "LineString",
                "coordinates": [
                        -55.9868404,
                        67.0981691,
                        167.342
                        -55.986836,
                        67.0981869,
                        167.342
                "coordinates": [
                        -55.9868611,
                        67.0981788,
                        167.342
                        -55.9868153,
                        67.0981771,
                        167.342
Thanks!
Kindest Regards,
Jacky
Software Engineer
NLT Digital
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220323/6d4426ab/attachment.html>
