[gdal-dev] About bug fix / patch release policy for older GDAL versions (setuptools >= 58.0 and GDAL <3.3 compatibility issues)
Even Rouault even.rouault at spatialys.com
Fri Mar 25 05:45:21 PDT 2022
ok, I missed this was on the pypi package.
I've tried to make a patch over 3.2.2. For now, I've uploaded it only to
https://test.pypi.org/project/GDAL/3.2.2.1/  . Can you test that and
confirm that works properly ? If so, I'll push it to pypi official.
I've tracked the changes in a patch/3.2.2.1 branch, sitting for now in
my fork:
https://github.com/OSGeo/gdal/compare/v3.2.2..rouault:patch/3.2.2.1?expand=1
I'll push that to OSGeo/gdal as well and tag once confirmed things work fine
Hoping I'm not going into troubles doing this stuff outside of our usual
release processes...
Even
Le 25/03/2022 à 13:13, snehal waychal a écrit :
> Dear Even, dear Bas,
> Thank you very much for the quick response and highlightingthe
> Debian/Ubuntu release policy aspects. And also about the link to the
> ubuntugis-unstable PPA.
> >/what you discuss here is all about the patch & backport policy of the/
> >/Debian GDAL package. You can try to file a bug to Debian and point to/
> >/the patch you'd want to see backported,/
> But just to be sure I haven’t misunderstoodyour response or
> misrepresented the original issue. The patch release I described is
> also needed in the official releases of the GDAL **python** package.
> If I am not mistaken, the GDAL team is taking care of source
> distributions on https://pypi.org/project/GDAL/
> <https://pypi.org/project/GDAL/>. I looked into released pypi versions
> and if I am not mistaken there is no patch release for v3.2.2 with fix
> for setuptools compatibility issue.
> So, if we could make a new patch release of the/*python* package of
> GDAL/ and push the sdist package to pypi.org <http://pypi.org>
> (something like 3.2.2.1, as I described in the previous email) then
> that would also solve the issue. Because as python developers, we
> install *python* packages via pip/pipenv/poetry and those package
> managers would pick the new patch release from pypi.org
> <http://pypi.org>. (The GDAL library component libgdal-dev v3.2.2 will
> still come from the debian system package repo and there is no issue
> with that).
> Hope I am not missing something obvious here. Please let me know.
> Thank you again!
> Regards,
> Snehal
> On Fri, Mar 25, 2022 at 12:29 PM Sebastiaan Couwenberg
> <sebastic at xs4all.nl> wrote:
>     of the
>     point to
>     > the patch you'd want to see backported, but I can't promise if
>     there
>     > would be interest in their maintenance team to create an updated
>     package
>     > with it (my understanding is that even if we'd release a new
>     3.2.x patch
>     > release, it wouldn't be packaged in LTS distributions. I'm not
>     sure how
>     > much of that is linked to Debian policy or availability of
>     people that
>     > do the work)
>     Packages in Debian stable releases only get updates to fix bugs of
>     severity important or higher [0]. GDAL patch releases also contain
>     changes for lower severity issues, it's not worth the effort to
>     vet all
>     those changes. Any changes to packages in stable also risk
>     introducing
>     regressions which are highly undesirable in LTS releases known for
>     their
>     stability.
>     People should be maintaining their own packaging repositories
>     where they
>     host packages with changes for their needs that cannot be easily
>     upstreamed to the package in the distribution itself. Scratching your
>     own itch was a corner stone of Open Source that people are seemingly
>     forgetting or never having known about in the first place.
>     [0]
>     https://www.debian.org/doc/manuals/developers-reference/pkgs.en.html#special-case-uploads-to-the-stable-and-oldstable-distributions
>     Kind Regards,
>     Bas
>       GPG Key ID: 4096R/6750F10AE88D4AF1
>     Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220325/63b47b95/attachment.html>
