[gdal-dev] Gitpod workspace with Ubuntu GDAL
    Matt.Wilkie at yukon.ca
    Tue Mar 29 13:55:49 PDT 2022
How to open a Gitpod<https://gitpod.io> machine with the version of GDAL in the Ubuntu software library.
  1.  Point browser at https://gitpod.io/#https://github.com/OSGeo/gdal
  2.  Login with Github credentials
  3.  In a couple of minutes the gitpod linux machine will be fired up and ready to use with Visual Studio Code open. There might be a cmake error, ignore it for now.
  4.  In the Terminal window install gdal (and whatever else you need).
# install gdal binaries, and git
sudo add-apt-repository -y ppa:ubuntugis/ubuntugis-unstable
sudo apt-get update
sudo apt-get install gdal-bin libgdal-dev
# verify gdal working
gdalinfo --version
# install gdal-utilties
python -m pip install swig/python/gdal-utils
# test gdal-utils working
gdal_edit
Optional: run tests to verify what parts of gdal are working
# Prep
python -m pip install -r requirements.txt
# Ensure gdal source code tree and the installed gdal binaries are the same version
git checkout v`gdal-config --version`
# and that python bindings match also
python -c "from osgeo import gdal;print(gdal.__version__)"
# Test only python utilities:
pytest pyscripts/
# All tests:
pytest
Pytest not found? Use python -m pytest instead. In next opening of bash shell it will work.
Result of investigation in https://github.com/OSGeo/gdal/issues/5442
Matt Wilkie
Geomatics Developer & Administrator
Environment | Technology, Innovation and Mapping
T 867-667-8133 | Yukon.ca<http://yukon.ca/>
Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220329/81a136a9/attachment.html>
