[gdal-dev] Trouble reprojecting feature that crosses antimeridian
Even Rouault
even.rouault at spatialys.com
Tue Mar 29 14:33:44 PDT 2022
Was a bug. Fix queued in https://github.com/OSGeo/gdal/pull/5543
Le 29/03/2022 à 22:30, Robin Wilson a écrit :
> Hi,
> I’ve been running into problems creating STAC items for images that
> cross the antimeridian. The geometries for the images are coming out
> as spanning the width of the whole world (from -180 to +180 degrees).
> With the help of the author of the tool I was using to create the STAC
> items (rio-stac), I’ve narrowed it down to a simple test case of
> reprojecting geometries (which is what the tool is doing internally).
> If you put the following GeoJSON for an antimeridian-crossing polygon
> in WGS 84 / UTM zone 1N in a file called test_32601.geojson:
> {"type":"Polygon","coordinates":[[[377120,7577600],[418080,7577600],[418080,7618560],[377120,7618560],[377120,7577600]]]}
> and then run the following:
> ogr2ogr -f GeoJSON -s_srs epsg:32601 -t_srs epsg:4326 out_4326.geojson
> test_32601.geojson
> The contents of the output file will be:
> { "type": "Polygon", "coordinates": [ [ [ -179.018099960087909,
> 68.666857319910392 ], [ -178.985579869598382, 68.299719485120988 ], [
> -179.976982644969041, 68.284942315413858 ], [ 179.974309855567753,
> 68.651801088224246 ], [ 180.0, 68.652259945574556 ], [ 180.0,
> 68.652259945541758 ], [ 180.0, 68.652259944541754 ], [ -180.0,
> 68.652259944541754 ], [ -180.0, 68.652259945541758 ], [ -180.0,
> 68.652259945610126 ], [ -179.018099960087909, 68.666857319910392 ] ] ] }
> In that output geometry there are longitudes of 180 and -180, so when
> plotted on a map it spans the whole width of the world.
> The author of the rio-stac library did a PR to try and fix this
> problem (https://github.com/developmentseed/rio-stac/pull/30), but it
> doesn’t seem to have fixed it for this example, as the underlying GDAL
> code used by his library (through rasterio, I believe) is giving this
> result.
> I find this result unexpected, but I have no knowledge of how GDAL
> deals with the antimeridian. Is this to be expected, or is this
> potentially a bug? If it isn’t a bug, is there any way around this?
> Best regards,
> Robin
> Dr Robin Wilson
> www.rtwilson.com <http://www.rtwilson.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220329/58df4442/attachment-0001.html>
