[gdal-dev] GDAL 3.4.2: gdalbuildvrt band selection bug
Pete Bunting
petebunting at mac.com
Wed Mar 30 13:48:47 PDT 2022
Thanks for the fix Even.
> On 30 Mar 2022, at 14:21, Even Rouault <even.rouault at spatialys.com> wrote:
> Pete,
> ouch, confirmed, and fix queued in https://github.com/OSGeo/gdal/pull/5547 . And the commit you mention was indeed the culprit.
> Potential workarounds (besides generating the VRT on GDAL <= 3.4.0)
> - if using gdalbuildvrt on a single source, you could just use "gdal_translate sen2_20210527_aber_subset.kea test.vrt -b 2", that will do the job equally well
> - if using multiple sources, you could also use gdal_translate with band selection on the VRT generated by gdalbuildvrt (without band selection) to extract only the band(s) you're interested in, but obviously that creates one more file
> (do not hesitate to file an issue in github for obvious regressions like that. emails tend to be easily forgotten)
> Even
> Le 30/03/2022 à 12:59, Pete Bunting via gdal-dev a écrit :
>> Hi,
>> With the release of gdal 3.4.2, gdalbuildvrt seems to have a bug when selecting image bands. It works OK when band 1 is specified but if other band(s) in the image are used without band 1 then it seg faults. I noticed there were some changes around checking bands in the release notes "change logic to check homogenous number of bands” and I had a quick look at the commits but cannot see where this is occurring.
>> # Works:
>> gdalbuildvrt test.vrt sen2_20210527_aber_subset.kea -b 1
>> # Seg Faults:
>> gdalbuildvrt test.vrt sen2_20210527_aber_subset.kea -b 2
>> ERROR 5: sen2_20210527_aber_subset.kea: GDALDataset::GetRasterBand(2) - Illegal band #
>> Segmentation fault (core dumped)
>> # Works:
>> gdalbuildvrt test.vrt sen2_20210527_aber_subset.kea -b 1 -b 2 -b 3
>> # Seg Faults:
>> gdalbuildvrt test.vrt sen2_20210527_aber_subset.kea -b 2 -b 3 -b 4
>> ERROR 5: sen2_20210527_aber_subset.kea: GDALDataset::GetRasterBand(4) - Illegal band #
>> Note, the input image I was using has 10 bands and these commands work with 3.4.1. I get the same seg fault on Mac, Linux and Windows ("Windows fatal exception: access violation").
>> Many thanks,
>> Pete
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
