[gdal-dev] ${GDAL_GIT_HASH} is not properly initialized
Even Rouault
even.rouault at spatialys.com
Thu May 5 14:56:16 PDT 2022
I managed to reproduce. Fixed per https://github.com/OSGeo/gdal/pull/5677
Le 05/05/2022 à 21:35, Jorge Gustavo Rocha a écrit :
> Hi,
> I'm compiling GDAl on local master, on Ubuntu, using default git.
> cmake is working, but I'm not able to install gdal afterwards.
> For some reason, when I run:
> sudo make install
> or
> sudo cmake --build . --target install
> I get the following error:
> -- Found Git: /usr/bin/git (found version "2.32.0")
> CMake Error at
> /home/jgr/dev/cpp/gdal/cmake/helpers/generate_gdal_version_h.cmake:27
> (string):
> string sub-command SUBSTRING requires four arguments.
> gmake[2]: *** [CMakeFiles/generate_gdal_version_h.dir/build.make:76:
> CMakeFiles/generate_gdal_version_h] Error 1
> gmake[1]: *** [CMakeFiles/Makefile2:4283:
> CMakeFiles/generate_gdal_version_h.dir/all] Error 2
> gmake: *** [Makefile:160: all] Error 2
> Looking into cmake/helpers/generate_gdal_version_h.cmake it seems to
> me that ${GDAL_GIT_HASH} is not properly initialized.
> I was compiling on local master. It seems that get_git_head_revision
> is not working properly, based on the parameters received.
> Does anybody noticed this issue when installing?
> Regards,
> Jorge
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
