[gdal-dev] Successfully built gdal 3.4.3 but failed to install with `sudo make install`
Even Rouault even.rouault at spatialys.com
Sat May 7 01:26:37 PDT 2022
This has been fixed yesterday per https://github.com/OSGeo/gdal/pull/5677
(and this is for GDAL 3.5.0, not 3.4.3)
Le 07/05/2022 à 04:51, Pei JIA a écrit :
> Hi, all:
> Finally, I successfully built gdal under Ubuntu 22.04, with gcc 11.2.
> However, when I tried to install with `sudo make install`, I got
> the following ERROR message:
> /➜  build git:(master) ✗ sudo make install
> /usr/local/bin/cmake -S....../gdal -B....../gdal/build
> --check-build-system CMakeFiles/Makefile.cmake 0
> /usr/local/bin/cmake -E cmake_progress_start
> ....../gdal/build/CMakeFiles ....../gdal/build//CMakeFiles/progress.marks
> make  -f CMakeFiles/Makefile2 all
> make[1]: Entering directory '....../gdal/build'
> make  -f CMakeFiles/generate_gdal_version_h.dir/build.make
> CMakeFiles/generate_gdal_version_h.dir/depend
> make[2]: Entering directory '....../gdal/build'
> cd ....../gdal/build && /usr/local/bin/cmake -E cmake_depends "Unix
> Makefiles" ....../gdal ....../gdal ....../gdal/build ....../gdal/build
> ....../gdal/build/CMakeFiles/generate_gdal_version_h.dir/DependInfo.cmake
> --color=
> make[2]: Leaving directory '....../gdal/build'
> /usr/local/bin/cmake -DSOURCE_DIR=....../gdal
> -DBINARY_DIR=....../gdal/build -DGDAL_SHA1SUM= -DGDAL_RELEASE_DATE= -P
> ....../gdal/cmake/helpers/generate_gdal_version_h.cmake
> -- Found Git: /usr/bin/git (found version "2.34.1")
> CMake Error at
> ....../gdal/cmake/helpers/generate_gdal_version_h.cmake:27 (string):
>   string sub-command SUBSTRING requires *four arguments*.
> make[2]: *** [CMakeFiles/generate_gdal_version_h.dir/build.make:73:
> CMakeFiles/generate_gdal_version_h] Error 1
> make[1]: *** [CMakeFiles/Makefile2:4317:
> CMakeFiles/generate_gdal_version_h.dir/all] Error 2
> make[1]: Leaving directory '....../gdal/build'
> make: *** [Makefile:149: all] Error 2
> Line 27 of file /....../gdal/cmake/helpers/generate_gdal_version_h i/s :
> *string(SUBSTRING ${GDAL_GIT_HASH} 0 10 REV)*
> There are *ALREADY 4 arguments*.
> Did anybody have the same issue ??
> Cheers
> Pei JIA, Ph.D.
> Email: jp4work at gmail.com
> cell in Canada:    +1 778-863-5816
> cell in China: +86 186-8244-3503
> Welcome to Vision Open
> http://www.visionopen.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220507/0d70ab06/attachment-0001.htm>
