[gdal-dev] nitfwritejpeg.cpp:(.text+0x104): undefined reference to `jpeg_vsiio_dest(jpeg_compress_struct*, _IO_FILE*)'
Brad Hards bradh at frogmouth.net
Sat May 7 00:18:43 PDT 2022
On Saturday, 7 May 2022 1:35:52 PM AEST Pei JIA wrote:
> Hi, all:
> It looks *libjpeg8-dev libjpeg-turbo8-dev* from Ubuntu 22.04's repo is *NOT
> compatible* with current GDAL git? Any suggestions?
I'm not seeing this. I just did a new install of kubuntu 22.04, installed
libjpeg8-dev and libjpeg-turbo8-dev, cloned gdal, installed python3-dev and
some other deps as suggested by the cmake output, and it runs to completion.
If it was incompatible, I would have expected a compile failure not a link
failure.
Do you possibly have some previous build products?
Also, do you need to rebuild your local podofo, brunsli, openjp2 or opencad
deps?
If none of that works, can you show the exact configuration you are trying to
build?
