[gdal-dev] GDAL 3.5.0 release candidate available
Greg Troxel gdt at lexort.com
Sun May 8 07:10:25 PDT 2022
Even Rouault <even.rouault at spatialys.com> writes:
> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
All on NetBSD 9 amd64.
I built this in pkgsrc, using autoconf (because that's how the package
is from 3.4.x).  It built fine, with minor changes in installed files.
(In addition to what's in NEWS, include/gdalcachedpixelaccessor.h but
that's ok as it is not surprising.)
Tests from gdal/autotest on release/35 were successful, with only one
failure, the best result I have ever seen.
> The GDAL-GRASS plugin sources and release process has been moved to
> https://github.com/OSGeo/gdal-grass
Given that nothing vanished from PLIST, I am guessing that the package
never built that, so I don't need to do anything.
After installing the updated gdal-lib and py-gdal packages, I rebuilt
qgis (becaues of the shlib bump), and starting it on a project with some
geopackage layers worked fine.
So from here it looks good.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220508/83a07a7b/attachment.sig>
