[gdal-dev] GDAL 3.5.0rc4 available (Re: GDAL 3.5.0 release candidate available)
Sean Gillies sean.gillies at gmail.com
Tue May 10 17:59:22 PDT 2022
Explicitly setting rpath in LDFLAGS solved my PROJ 9 problem. This feels
like a regression. It isn't necessary for Linux and wasn't necessary for
autotools builds of PROJ 8.2.1.
Back on topic: GDAL 3.5.0rc4 seems fine.
On Tue, May 10, 2022, 4:18 PM Sean Gillies <sean.gillies at gmail.com> wrote:
> Thanks, Alan!
> I feel like we're in the middle of going backwards to go forwards when it
> comes to FOSS4G software builds.
> On Tue, May 10, 2022 at 4:05 PM Alan Snow <alansnow21 at gmail.com> wrote:
>> This might be a helpful reference:
>> https://github.com/pyproj4/pyproj-wheels/issues/45
>> On Tue, May 10, 2022, 4:33 PM Even Rouault <even.rouault at spatialys.com>
>> wrote:
>>> Sean,
>>> So your issue is with a GDAL autoconf build. I can't see any significant
>>> changes in configure.ac between GDAL 3.5.0 and 3.4.0 related to rpath.
>>> This has probably not changed in years. I do see in your logs that the
>>> linking line of GDAL has a
>>>  -rpath /usr/local/lib
>>> and that there's a /usr/local/lib/libproj.25.dylib file
>>> But perhaps the issue is more with the PROJ CMake build (hypothesis that
>>> you could check by testing with a PROJ 8.2.1 autoconf build) ? I don't
>>> know... Mac + rpath is hostile territory for me.
>>> Does running a GDAL binary, like gdalinfo, works before using that
>>> delocate module ?
>>> Yes 5413 is CMake specific.
>>> Even
>>> Le 10/05/2022 à 23:02, Sean Gillies a écrit :.
>>> Hi Even,
>>> I'm running into a problem with GDAL 3.5.0rc4 and PROJ 9.0.0 on macos.
>>> It occurs when I use https://github.com/matthew-brett/delocate to
>>> relocate GDAL and its dependencies into rasterio wheels.
>>> The error:
>>> ERROR:delocate.libsana:
>>> @rpath/libproj.25.dylib not found:
>>> Needed by: /usr/local/lib/libgdal.31.dylib
>>> Search path:
>>> ERROR:delocate.libsana:@rpath/libproj.25.dylib not found, requested by
>>> Here is its context:
>>> https://github.com/rasterio/rasterio-wheels/runs/6375882173?check_suite_focus=true#step:4:4025
>>> I searched the GDAL tracker for related issues and only found
>>> https://github.com/OSGeo/gdal/issues/5413. It looks like it could be
>>> related, but it also looks like the fix is cmake specific and isn't
>>> available for autotools builds. Is that correct?
>>> On Tue, May 10, 2022 at 8:13 AM Even Rouault <even.rouault at spatialys.com>
>>> wrote:
>>>> Hi,
>>>> I've issued a rc4 with the following fixes w.r.t rc3:
>>>> * fix build error with CMake >= 3.10.2 and < 3.11
>>>> * fix build errors with Fedora mingw32
>>>> Updated archives:
>>>>    https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.xz
>>>>    https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.gz
>>>>    https://download.osgeo.org/gdal/3.5.0/gdal350rc4.zip
>>>> Even
>>>> Le 06/05/2022 à 15:06, Even Rouault a écrit :
>>>> > Hi,
>>>> > I have prepared a GDAL/OGR 3.5.0 release candidate.
>>>> > NEWS at:
>>>> >   https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
>>>> > Note the first item about the new CMake build system, and the
>>>> > deprecation of the autoconf & nmake build systems that will be
>>>> removed
>>>> > in GDAL 3.6.0
>>>> > Pick up an archive among the following ones (by ascending size):
>>>> >   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
>>>> >   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
>>>> >   https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
>>>> > A snapshot of the gdalautotest suite is also available :
>>>> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
>>>> >   https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
>>>> > A snapshot of the documentation is at:
>>>> >   https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
>>>> > The GDAL-GRASS plugin sources and release process has been moved to
>>>> > https://github.com/OSGeo/gdal-grass
>>>> > I'll call for a vote promoting it to next week if no serious problems
>>>> > are reported before.
>>>> > The "release/3.5" branch has been created for all bug fixes related
>>>> to
>>>> > 3.5.x. master is now targetting 3.6.0dev.
>>>> > Best regards,
>>>> > Even
>>>> http://www.spatialys.com
>>>> My software is free, but my time generally not.
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Sean Gillies
>>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> -- http://www.spatialys.com
> Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220510/d1b3f776/attachment.htm>
